so i have a 1920x1080 mp4 movie that i'd like to play on my ps3. xilisoft video converter can convert it to an avi. so i then use aviaddxsubs which makes the avi into a divx with subs. it plays on the pc fine but it isn't supported in ps3.
other avis that i downloaded and convert with aviaddxsubs work fine in the ps3.
i tried a couple of formats in xvid4psp, but it takes 4 hours for conversion, i don't know which to use. the two formats i've tried were very bad quality, even with names like "550mb xtreme". i'd like to convert to a 1024x720 size of dvd quality avi that can play on the ps3. any program that does it better than xilisoft and xvid4psp?
Results 1 to 9 of 9
that's for adding subs and converting to divx. i'm asking for help with converting a mp4 to avi that would play on a ps3
What kind of AVIs are being created by the Xlisoft converter? You might run one of the AVIs through MediaInfo (in Tree/Text mode), cut and paste the information here, and someone might be able to tell you what the PS3 doesn't like about the video.
If cameras add ten pounds, why would people want to eat them? -
weird, i read the media info from vlc, and it seems to be a mpeg-4 file even though the extension is avi. (converted with xilisoft) vlc media info codec: h264 mpeg-4 avc part 10 res 320x240 frame rate 25 decoded format: planar 4:2:0 yuv full scale
If you are re-encoding the video then you might as well burn the subs into it and if you do that then you can re-encode to a MP4 file which means you can leave the audio "as is" and you'll probably get better video quality (although the encoding will take longer).
Also, make sure your encoder creates AVIs using DivX or Xvid to encode the video. The PS3 likely only recognizes those video codecs, for AVI videos. Using MP3 for audio with the AVIs is probably also a good idea, too, though the PS3 might be a little more forgiving about the audio codecs.
It appears you have an AVI using h.264-encoded video, and most standalone players that play AVIs aren't likely to accept it, save for media players like the WDTV.
(I haven't tried to play AVIs on a PS3 in quite a while, and don't have one around at the moment to test.
Convert MKV to PS3
By ThiagoMicali in forum Video ConversionReplies: 2Last Post: 24th Oct 2011, 20:49 -
how to convert ps3 movie to xvid/avi?
By volam1 in forum Video ConversionReplies: 2Last Post: 24th Feb 2010, 15:13 -
convert for ps3
By pensioner in forum Newbie / General discussionsReplies: 2Last Post: 27th Apr 2009, 20:26 -
How to convert a H.264 avi to play on PS3?
By fwtong in forum Video ConversionReplies: 7Last Post: 30th Jul 2008, 02:04 -
PS3 Video 9 - .AVI to PS3 - Settings
By dec60228 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 14:48
