I've looked everywhere and I can't see anyone saying that it sharpens. Could anyone confirm this? If it sharpens, what percentage does it sharpen by?
I usually do McTemporalDenoise with the default of 150% sharpen then I use QTGMC after it. I can't use it before otherwise it drops the encoding speed to a crawl. So I was just wondering if QTGMC eradicates the sharpening done by McTemporalDenoise or if QTGMC sharpens itself. I searched for "contra" in the avsi file but found nothing.
The switch is "sharpness"
QTGMC(sharpness="x")
where x is the value . 1.0 is default (IMO it's too high), some decimal value would be lower e.g. 0.5
It doesn't eradicate it, but QTGMC denoises and antialiases, that will reduce the perceived "sharpness" of the input video - hence the reason for "contra sharpening" . If you left sharpness=0 to disable it, you will see the video will become much softerSo I was just wondering if QTGMC eradicates the sharpening done by McTemporalDenoise or if QTGMC sharpens itself. -
Depending on you other settings, QTGMC does sharpen. see the content of the QTGMC script (and the QTGMC documentation, which should come with the script as a QTGMC.html file) and how "Sharpness" influences other settings and is influenced by other settings.Thanks I know how to use it, I was just asking if it sharpens or not.
Using Avisynth MT with QTGMC
By agni451 in forum Video ConversionReplies: 11Last Post: 15th May 2014, 07:37 -
Problems making QTGMC deinterlacer work
By brassplyer in forum EditingReplies: 56Last Post: 9th Dec 2012, 22:06 -
Using QTGMC in ffmpeg
By agni451 in forum Video ConversionReplies: 1Last Post: 10th Nov 2012, 10:16 -
QTGMC Help
By TuFFrabit in forum Newbie / General discussionsReplies: 16Last Post: 23rd Jun 2012, 06:53 -
Help me get started with QTGMC
By JackDanielZ in forum Video ConversionReplies: 20Last Post: 3rd Jun 2012, 09:04
