  1. I have a video and I want to take the .avi and convert it to another .avi to uncompressed 15 RGB, is there a program out there that help me do it? Any idea what it is called?
    Thanks in advance.
  2. Originally Posted by xboxown View Post
    Thanks in advance.
    What do you mean by "uncompressed 15 RGB" ?
    Do you mean RGB24 ? 8bits per channel ?
    If so, virtualdub can do it
    Or did you mean 5bits per channel? vdub can do that too
  3. Originally Posted by poisondeathray View Post
    Thanks in advance.
    I tried virtualdub but I do not see the option of 15 bit RGB. I only see 16 bit 555 as the choice is that the samething as 15 bit?
  4. I don't know what it is in vdub but ffmpeg can do it as well.
    ffmpeg -i input.avi -pix_fmt rgb555le -acodec copy output.avi
    edit:
    I just did a quick test both appear to be RGB555 (5 bits per channel, 15 bits total)
  5. Member Cornucopia's Avatar
    What do you really want/need? For what purpose?
