Instead of the normal firewire cable?
Seems the firewire port on my laptop is buggered, so thought this cable might be OK?!
http://www.ebay.com.au/itm/USB-to-IEEE-1394-Firewire-4-Pin-4-feet-Extension-Cable-/300...ht_1831wt_1162
Results 1 to 13 of 13
no they don't work for firewire cams.
That type of cable only works for firewire hard drives. Not for DV camcorders.
If your laptop has a PC Card slot you can use something like this:
http://www.amazon.com/TRENDnet-2-Port-FireWire-Card-TFW-H2PC/dp/B0007L72N0 -
and if it doesn't have a slot, then maybe one of these.
the unit has conections in both front/back for video input and output. in this case, the dv video stream travels from the firewire->usb->pc.
if necessary, google search for the best price. this works on my pc and netbook under xp home/pro. i'm using it now, watching tv on my pc while typing this message...
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+...version+14.htm
* this is the moviebox plus, model 710-usb -
http://www.pinnaclesys.com/PublicSit...version+14.htm
$170 on Ebay.
Thanks but might as well get the port fixed or put it toward a new laptop. -
This should work:
http://www.amazon.com/IO-Crest-Firewire-ExpressCard-SY-EXP30013/dp/B003XU0CY8/ref=sr_1...+card+firewire
thanks. -
Yes, those express cards should work. Try to find one that specifies the TI firewire chip. It has the best compatibility.
Firewire and USB 2.0 Cable quality - does it matter???
By tarrickb in forum Capturing and VCRReplies: 21Last Post: 29th Mar 2012, 13:59 -
Samsung micro USB-B to USB-A cable
By luigi2000 in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2011, 15:05 -
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Aug 2010, 13:28 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 14:36 -
firewire to usb 2 cable
By pavilion1250 in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2009, 22:01
