JVC SR-V101US -> TBC-1000 -> Canopus ADVC-55 -> WinDV
I have a number of these setup and they've been running every day for the last couple years. In the last week two of the VCR's stopped working with a message something like "clean heads". I used a dry and wet tape cleaner multiple times like we usually do every couple weeks and nothing worked, so I replaced the VCR's with a couple new ones I had in stock.
Today I had time to pop the tops and look inside... I prepared a soft cotton cloth slightly damp with a solution of iso/h2o/dawn that I use for film cleaning. I wrapped the damp cloth over my finger and went up and down across the head while rotating it slowly for two revolutions... it took 8 times doing this until the cloth was clean!
HOLY COW!!!
Lesson learned... pop the top and clean for regular maintenance!!
Brian
	Don't wipe the heads going up and down,this can break the heads,just rotate the drum with the cloth,its better to use a foam q-tip,cotton can snag the heads and break them. I think,therefore i am a hamster.
	Thanks for the tip! I finally looked up how a VCR works and didn't know the read/record heads were the two little slots in the rotating drum. I can see where thread might catch whatever components are inside that slot and yank something apart. I saw one article that describes using iso saturated paper held against the rotating drum to pull the dirt out... I like that idea too.
  Best way to clean VCR headsBy Theresa in forum RestorationReplies: 67Last Post: 18th Sep 2023, 19:14
  Best PAL VCR player with 6-heads - multi region/system would be preferredBy jbloggs in forum DVD & Blu-ray RecordersReplies: 7Last Post: 16th Mar 2012, 16:20
  Do I need to clean the heads on a CamcorderBy piperpilot12w in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2010, 02:56
  Aligning VCR Heads?By frozentax in forum RestorationReplies: 13Last Post: 3rd Apr 2009, 20:35
  dealing with dirty heads/tapes?By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th May 2008, 10:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
