Yes, i got this movie to be joined with srt subtitles. But when i play the movie, there were no subtitles. help me pls . ty![]()
1st analyse your created mkv with MediaInfo to check if the mkv contains the subtitle stream, if it does you player probably doesn't support srt subtitles inside mkv files.
If the mkv doesn't contain the subtitles you did make a mistake when using mkvmerge.
2nd you could also reencode the video and hardcode the subtitles into the video stream,... -
No. i dont think there were any problems occured. Eveything went smoothly...and im using VLC Player. Either way, can u explain how to reencode the video and hardcore the subtitles. I'm not used to it and dont really know what is that for I really appreciate your help. Thanks :>
And did you enable the subtitle in vlc? It's not on by default.
If you explored or played with the menu's to find out what's available you would have found "subtitles track" under video.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
And it can be on by default if you set "Yes" for Default track flag and Forced track flag in General track options for the "highlighted" .srt file
using mkvmerge gui
By zoloabc in forum EditingReplies: 8Last Post: 26th Jun 2014, 13:44 -
MKVMerge GUI Suddenly Not Working
By ZodiacBeast in forum EditingReplies: 3Last Post: 16th Sep 2012, 23:42 -
get chapters from DVD with mkvmerge GUI ?
By lovelove in forum DVD RippingReplies: 2Last Post: 12th Aug 2011, 19:09 -
mkvmerge GUI 4.4.0 Vs mkvmerge GUI 2.0.2
By Manospetrucci in forum Video ConversionReplies: 2Last Post: 6th Jan 2011, 21:34 -
Trouble with mkvmerge gui
By nzdreamer55 in forum EditingReplies: 0Last Post: 25th Nov 2010, 14:07
