The Womble forums are down so I can't ask there. Does anyone know how to set Womble MPEG Video Wizard 4 to _not_ split into different vobs and to keep to a single vob output? Conversion apps like AutoGK and even AviDemux know that they take consecutively-numbered vobs and turn into one AVI (at least, AviDemux knows when it prompts you and you tell it to; AutoGK just does this automatically), but I don't know how to ensure WinFF will cobble the vobs together so it would be easier just dealing with one large VOB.
I've googled over last few weeks and several times looked through the help file and have looked through the preferences in Womble itself but I don't recognize or see where to do this.
Can someone please advise how?
Thanks!
Export to mpg in mpeg video wizard?
Vobs should ALWSAYS be splitted when they are authored to a dvd. -
If you want to convert a DVD into smth, but your conversion tool only imports single VOB, you can join VOBs in PGCDemux ('create PGC VOB' option).
If you want to use womble for this, it will only output an 'mpg'. Previously you can join the video (from standard DVD folder) on timeline by using 'DVD tool' import option.
You need the complete DVD folder (with ifo's) in both cases.
Working with VOB Files in Womble MPEG Video Wizard
By toscano in forum DVD RippingReplies: 2Last Post: 29th Jan 2009, 13:33 -
Womble video wizard mpeg dvd
By Remyisme in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 14:47 -
Frameserving Womble Mpeg Video Wizard
By tmw in forum Video ConversionReplies: 13Last Post: 1st Nov 2008, 08:53 -
Womble MPEG Video Wizard destroys audio?!
By noemi7 in forum EditingReplies: 3Last Post: 16th Jun 2008, 10:18 -
settings for Womble MPEG Video Wizard DVD
By Vril-ya in forum EditingReplies: 0Last Post: 20th May 2008, 19:18
