Trying to bring in an image into Movie Studio 10 to use in a menu. It's a jpeg from CS5 in sRGB. When I bring it into import media and then the time line the color drastically changes. Should I use a different color space or format in CS5 to use on imported image? Thanks!
In what way does the color change drastically ?
jpeg should work fine - sounds like a bug.
You can try png or tiff as well as a workaround for now
I don't think movie studio has color management, so don't bother embedding a profile -
Nope. Didn't help. Tried png, tiff and jpeg all have a yellowish green cast. Tried 4 different images. Even tried bringing into MS12 demo. Same thing greenish yellow. MS has a couple fx color corrections but not even close to sensitive enough.
To clarify - Is this photoshop CS5 and vegas movie studio 10 ?
People do this everyday without problems in those programs, seems like it's isolated to your setup or computer . I would suggest uninstall/reinstall but you already tried a different demo version - and that should rule out old installation issues
Are you viewing on the same monitor for both ? graphics card calibration ? how about viewing the image in another application , even windows picture viewer or a web browser - does it appear ok?
What about other known images that you have saved before (maybe photos from an old camera shoot), how do they look in photoshop, vs. movie studio vs. other application ? -
Sorry, yes I meant Photoshop CS5 and Movie Studio Platinum10. I only use one monitor. Not sure how to calibrate a graphics card. I am using a NVIDIA GTS 240. I used the images in ProSHow Producer slideshow software and also no problem with Windows viewer. And I tried several additional images in that i have used before without problems in other software so the only problem seems to be bringing an image into MS10/12.
That would suggest an issue specific to movie studio ... But many people use that and import stills like png, jpg, without issues...
Sorry, not sure what's going on . Maybe you can contact Sony for support
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Can't restore win7 backup image from server with win7 image restore.
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 14th Dec 2010, 19:56 -
Best Method for Converting S-VHS and Bringing into Sony Vegas
By Great Googly Moogly in forum Video ConversionReplies: 9Last Post: 20th Mar 2010, 09:30 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 15:26
