    Dec 2012
    Germany
    hi,
    recently I bought the DVD-Player Tevion DVD-2002. It workes fine, but some DVD are not recognized.
    Now I'm seaching the latest Firmware but can't find it.
    The manufacturer siemssen no longer has a homepage.
    On the medion-site the modell is not listed.
    The only Version I found on ZDNet was V2.49, which is the Version already installed on the player.
    Can anyone help me?
    Maybe someone has the files and can send it to me.
    I would also be thankful about a manual for this player.
    Thanks in advance,
    rabu63
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by rabu63 View Post
    hi,
    Can anyone help me?
    Thanks in advance,
    rabu63
    "Firmware" isn't going to help if you are trying to play DVDs from other regions.
    Dec 2012
    Germany
    Thank you for answering.
    The DVDs I mentioned are not with foreign region codes (btw: there is a code to switch in codefree-modus).
    The topic is VCD, SVCD and burned DVDs.
    In many posts it is mentioned that the player gets the ability to read more formats with a firmware-update.
