Results 1 to 14 of 14
    Oct 2012
    Anadia
    It has really been a trial and error to find out this. I tried many HD movies (mp4, mkv, etc), with many encoding types, and sometimes doesn't play sound, others the picture, and sometimes neither audio or image.
    I figured by now most of the times, the problem is with AAC audio. It only recognizes AC3. But the image encoding it's always a mistery. I never know. I think x264 encoding works most of the times, but there are exceptions.
  2. Member DB83's Avatar
    Jul 2007
    Isn't there such a thing as a user manual ?
    Oct 2012
    Anadia
    Yes, but it doesn't mention any encoding conditions, bitrates or whatever. Just says it reads mkv, mp4 and avi.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    In the quick reading I've done on it....it only reads MPEG2 and Divx/Xvid.
    As far as other features go, Philips BDP2700/12 Blu-ray player is quite standard. The file formats supported are MP3, WMA, WAV for audio, MPEG 2, DivX Ultra and XviD for video and JPEG for pictures.
    http://tech2.in.com/reviews/bluray-players/philips-bdp270012-just-another-bluray-player/186632
    Oct 2012
    Anadia
    This is the file description of a movie i played and it worked fine (sound and picture)
    ViDEO CODEC....- x264
    ViDEO BiTRATE..- 2124 kbps
    RESOLUTiON.....- 1280 x 536
    FRAMERATE......- 23.976
    SETTiNGS.......- MP4 PSP
    AUDiO CODEC....- AC3 6 chnls
    AUDiO BiTRATE..- 384 kbps
    FiLE SiZE......- 2.27 GB
    ENCODER........- 26K
  6. Member DB83's Avatar
    Jul 2007
    Well methinks that no player would go in to the specific detail of encoding as to the general user that would be akin to water off a duck's back.
    The clue is in the words 'blu-ray'. If the video meets the formats of that then it really should play. If it does not then it really should not be called a blu-ray player.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Not according to what I've read.
    Oct 2012
    Anadia
    But it's true. This is from Dark Knight Rises, and also works fine:
    Video
    Video Format......: AVC
    Video Codec.......: x264 core 125 r2200 999b753
    Bitrate...........: 2 750 Kbps
    Frame Rate........: 23.976 fps
    Width.............: 1 280 pixels
    Height............: 720 pixels
    aspect ratio......: 16:9
    Audio
    Format..........: AC-3
    Bitrate.........: 448 Kbps
    Channels........: 6 channels
    Sampling Rate...: 48.0 KHz
    Language........: English
  9. Member DB83's Avatar
    Jul 2007
    Wel, the first example you posted is NOT HD in the accepted sense of the word. The second example is.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Then just encode what you want with the same software/setting that you encoded your Dark Knight Rises disc from.
    Oct 2012
    Anadia
    I didn't encode the movie. At least in my country there are LEGAL websites where we can pay and download movies. That's where i got them.
  12. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Of course you did. We ALL believe you.
    Oct 2012
    Anadia
    Movies here are subtitled. Of course audio is in english!
  14. Member DB83's Avatar
    Jul 2007
    Wow. Christmas just came early. Ding Dong. I hear bells ringing.
