Hello and here is my first post on your awesome forum!
I have an AVI file, that plays on WMP in 4:3 PAR, while it is a 16:9 PAR movie.
I want to change the PAR of the AVI file, without reencoding it.
I tried using MPEG4 Modifier, but it doesn't make a difference at all.
From MPEG4 Modifier I get the following info for the AVI file:
Packed bitstream: Yes
QPel: No
GMC: No
Interlaced: No
Aspect ratio: Square pixels
Quant type: H.263
FourCC: XVID
User data: DivX503b1393p
XviD0050
Virtualdubmod shows the following info for the AVI file:
FourCC code: FourCC:XVID, XviD MPEG-4
And Avidemux shows the following info for the AVI file:
Codec 4CC: XVID
Aspect Ratio: 1:1
Frame Rate: 29.970fps
Image Size: 576x432
Is there any other program I could try to change the PAR other than the MPEG4 Modifier, without reencoding of course?
And finally if there is no solution to my problem, because of the AVI limitations, would you recommend converting the AVI to an MP4 or some other Container format?
Results 1 to 14 of 14
Welcome to the forum
You're referring to DAR, not PAR, correct ? You want it to display as 16:9 ?
maybe you have a player issue ? mpeg4modifier should work on any xvid/avi . Have you tried something else like vlc, mpchc, smplayer to rule out a playback configuration issue ?
what does mediainfo view=>text say about the source file, and mpeg4modifier processed file ? -
Hello poisondeathray! Thank you for your rapid answer!
Yes, my bad, it's DAR that I want to change. The PAR of the file is 1:1. But anyway changing the PAR wouldn't that change the DAR also?
Ok, just installed Mediainfo, and on the original file says 4:3 DAR:
General
Complete name : J:\DOWNLOADS\Video Programs\MPEG4Modifier145\XYZ.avi
Format : AVI
File size : 702 MiB
Duration : 58mn 45s
Overall bit rate : 1 669 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 58mn 45s
Bit rate : 1 465 Kbps
Width : 576 pixels
Height : 432 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.197
Stream size : 616 MiB (88%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 2000
Duration : 58mn 45s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 80.7 MiB (12%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
While on the processed file (by MPEG4Modifier) I get the following info:
General
Complete name : J:\DOWNLOADS\Video Programs\MPEG4Modifier145\XYZ (16-9).avi
Format : AVI
File size : 702 MiB
Duration : 58mn 45s
Video
Codec ID : XVID
Duration : 58mn 45s
Width : 576 pixels
Height : 432 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Audio
Format : AC-3
Codec ID : 2000
Duration : 58mn 45s
Bit rate : 192 Kbps
Bit depth : 16 bits
Oops , just checked that with Divx Player, the new video file (converted from mpeg4modifier), does play at 16:9 DAR!!
So mpeg4modifier did the job, it's just that the WMP can't play it normally.
But since I play all my videos with WMP, I'd like to find another workaround to make that happen.
Which is the best program to convert the AVI to MP4 container (without reencoding) and also configure the DAR of the MP4?
I believe that WMP does play MP4 files. -
If you're not fussed about the format, MKVMergeGUI is quite fast at remuxing, and it'll open AVIs and remux them as MKV while letting you change the aspect ratio along the way. I always use MKV rather than MP4 as it'll hold more audio/video types than MP4 and MKVMergeGUI makes playing with MKV files very easy. MP4 kind of sucks..... in my opinion..... and none of the MP4 remuxers I've tried are as much fun to play with as MKVMergeGUI.
I've no idea if WMP can play MKV files as I can't imagine contemplating the idea of considering the possibility of ever using it, but if you install the Haali media splitter it should. I gotta ask..... what is it about WMP that makes you like it? -
It's not up to WMP to adjust the DAR. It's the filters that are used for playback. Check your DirectShow AVI file reader/splitter and Divx/Xvid decoder and make sure they are passing the PAR/DAR information properly. Use GraphStudio to see what filters are used.
Thanks hello_hello. MKV is the ultimate container for me, but I believe it's not working very well with WMP, so it's a no go.
Jagabo: I prefer much more WMP to other players just because of the explorer integration and the amazing way playlist works. For example VLC and Divx Player are much better players, but when it comes to playlists they are much of a hassle for no reason. -
All you have to do is install an MKV reader/splitter like LAV Filter or Haali.
I didn't tell you to use another player. I gave you way to diagnose your problem. -
I used Haali in the past and I really didn't like it. It loaded my system with lots of codecs, most of them that I didn't use them ever. And the configuration of those codecs was a big mess. From then I prefer to play MKV files with Divx Player. It is simple. I like that.
I have no idead on using GraphStudio. Is it a simple task or does it get complex? -
Try MPC-HC if you want something different to play MKVs. It has a playlist function but to be honest I've never used it. It'll play all the common formats "out of the box" without the need for additional codecs or splitters etc and it's a pretty good player, but as I said if you install the Haali splitter, WMP should play MKV files just fine.
Thanks hello_hello!
I'm satisfied with Divx Player, no need to get another one. And if I wanted a more sophisticated player I think I would end up with VLC.
Can I change the pixel aspect ratio in an x264 AVI without reencoding?
By Calidore in forum Video ConversionReplies: 24Last Post: 16th May 2018, 18:24 -
How to encode xvid with h.263
By kenryuakuma in forum Video ConversionReplies: 33Last Post: 27th Aug 2011, 21:43 -
how to change aspect ratio (PAR) in AVI without reencoding
By deejay.2001 in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 11:33 -
XviD Quantization type, H.263 vs MPEG; and GMC for hand recorded material
By carlaron in forum Video ConversionReplies: 41Last Post: 2nd Mar 2010, 23:36 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 21:56
