I just downloaded the trial version, but I'm having trouble getting it to work right.
Basically I'm trying to resize an mkv file and convert it into avi/xvid. The conversion starts nicely but claims to be "complete" after about 10 seconds. It produces a 42-second long, but perfectly functional avi file. The original video is 45 minutes long, so that's not right.
I don't know if this is perhaps a trial version limitation? It doesn't seem to be noted anywhere if it is.
I'm on OSX 10.5.8. Intel mac pro 3.1, and using ffmpegX 0.0.9y.
Yes, ffmpegX has a few (2) limitations for the unregistered version, which are listed on the website and greyed out in the program. There is no time limit on conversions.
The error is that the underlying ffmpeg version actually thinks that the source file ends after 42 seconds, or finds some other reason why it can't continue. Maybe a glitch in the file.
You'll find that player software can be a bit more forgiving than conversion apps, when it comes to media files with small errors.
Encore converts 5.1 to stereo
By koberulz in forum Authoring (DVD)Replies: 8Last Post: 24th Oct 2011, 23:28 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 23:14 -
converts to dvd but its always to big
By dylanvega123 in forum Video ConversionReplies: 3Last Post: 5th Aug 2009, 18:53 -
WinAvi converts with No Sound
By Yanez in forum Video ConversionReplies: 5Last Post: 12th Sep 2008, 21:12 -
Gotsent..converts to where?
By macman89 in forum Video ConversionReplies: 0Last Post: 24th Jul 2008, 19:16
