5 questions. If a 720p, 720i, 1080p or 1080i video file from an AVCHD consumer camcorder...
1. ...is imported into a Premiere Pro CS5 sequence with the same specs as the video file, then Premiere Pro CS5 will maintain rec.709 ? Or it will convert to rec.601 ?
2. ...is transcoded to Cineform, and imported into a Premiere Pro CS5 sequence with the same specs as the video file, then Premiere Pro CS5 will maintain rec.709 ? Or it will convert to rec.601 ?
3. ...is transcoded to Cineform, and then imported into a Premiere Pro CS3 sequence with the same specs as the video file, then Premiere Pro CS3 will maintain rec.709 ? Or it will convert to rec.601 ?
4. ...is imported into a Sony Vegas Pro 10 project with the same specifications as the video file, then Vegas Pro 10 will maintain rec.709 ? Or it will convert to rec.601 ?
5. ...is imported into a Sony Vegas Pro 8 project with the same specifications as the video file, then Vegas Pro 8 will maintain rec.709 ? Or it will convert to rec.601 ?
Results 1 to 1 of 1
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28 -
Rec.709 to RGB24 to Rec.601
By Anonymous344 in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 19:40 -
Reds look wrong for Rec.709
By Anonymous344 in forum Newbie / General discussionsReplies: 11Last Post: 23rd Apr 2011, 19:14
