I am trying to capture the audio stream from this radio station:
http://www.zoomerradio.ca/listen-live/
I am trying to capture the AM, but the FM might also be worth capturing, esp if they both use the same streaming protocol.
I tried Stream Hijacker but that didn't work.
I tried Freecorder, and that seems to work. Freecorder installs in your browser and captures and converts to mp3 on the fly, which in the end is probably what I will use.
HOWEVER, I first would like to capture just the stream directly from the radio station just to see what they are streaming. I may decide to capture the raw stream (especially if it is a low bit rate) and then later convert to a relatively low bit rate mp3, or do no converting at all, if the raw stream can be played with a common software player.
	AM URL: http://67.196.136.224:8015/;stream.mp3
 FM URL: http://stream.classical963fm.com:8017/;stream.mp3
 I got the URLs by starting the players then viewing the page source.Last edited by jagabo; 20th Dec 2012 at 21:14.
	Thanks. Not sure how you got that. If you look at the page source of the player, its rather lengthy (see partial screenshot of the AM and FM stations). I used the url you gave me and did a Find Next, and the url is therefore in blue (green for FM). But I don't know how you were able to determine that was the right info from such a lengthy page of info. I guess you just have to know what you are looking for. At any rate, since those are mp3 streams, I can use the tiny software, Streamripper32 to capture the mp3 stream. Last edited by jimdagys; 21st Dec 2012 at 00:41.
  Aver DarkCrystal HD Capture Station C874By havelka in forum Capturing and VCRReplies: 5Last Post: 4th Aug 2012, 10:23
  AVerMedia DarkCrystal HD Capture Station - Good for Restoration?By djnice in forum RestorationReplies: 11Last Post: 22nd May 2012, 15:49
  Here's an interesting question, recording a streaming radio stationBy Nator in forum AudioReplies: 4Last Post: 29th Jan 2012, 14:30
  Capture video on Archos DVR Station?By mark23 in forum Capturing and VCRReplies: 2Last Post: 17th Dec 2010, 05:35
  WQXR 96.3 FM classical music radio station moves to 105.9 FM, New YorkBy vhelp in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2009, 22:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
