I am on XP & is this possible ? Basically I want to take trailers & make them full screen for iPad etc
if you only change the aspect ratio, the ipad will playback the clips stretched,... -> sounds like a bad idea
That aside Quicktime pro should be able set the crop&scale flags the mov container allows, see: http://www.designtalkboard.com/tips/web/crop-quicktime-movie.php
(not sure if iPad supports this, but since mov is an apple container it should,..)
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 19:12 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 11:33 -
Aspect Ratio Change
By VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 12:01 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 14:14 -
How to change aspect ratio?
By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 11:49
