I use Premiere Pro CS3 to import the MPEG2 clips from the camcorder, edit them, and correct their tonality and colors. Then I export the Premiere sequence to uncompressed AVI signpost, with Debugmode FrameServer and it's RGB24 option. Then I use AviSynth to deinterlace, resize, denoise, etc, and frameserve to x264 encoder.
From what I understand, I have to convert to YV12, because those AviSynth filters cannot work with RGB input. But I don't understand how to properly convert from RGB to YV12 in AviSynth. For example, how can I make sure there will not be tonality shifts or color shifts, after the RGB to YV12 conversion ? Or how can I get exactly what I see in Premiere, in terms of tonality and colors, after the conversion to YV12 ?
There are 3 values than can be attributed to the "matrix" parameter from the ConvertToYV12() function:
But what is confusing to me is that, after I analyse the original MPEG2 clips with DGIndex, in the Information window it says:Code:ConvertToYV12(interlaced=true, matrix="pc.601") # keeps full range [0,255] # or ConvertToYV12(interlaced=true, matrix="rec709") # scales to TV range [16,235] # or ConvertToYV12(interlaced=true, matrix="pc.709") # keeps full range [0,255]
So, several MPEG2 clips with colormatrix BT.470-2 are imported into Premiere Pro CS3 timeline, some cuts are made, some dip to black transitions are applied, then the Fast Color Corrector is applied on many of the clips, and the Three-Way Color Corrector is added on some clips. In this process:Code:Colorimetry: BT.470-2 B,G*
1. Clips are converted from YCbCr to RGB ? What happens with the original colormatrix ? It converts that too ? From BT.470-2 to something else ?
2. When exporting the sequence to avi signpost, those exported frames have the exact same colormatrix as the frames inside the timeline, wich are displayed in Premiere UI ?
3. How do I determine the proper value for the matrix parameter for "ConvertToYV12()", so that what I see in Premiere UI is what I get after RGB to YV12 conversion ?
4. How do I determine the proper value for the --colormatrix parameter for x264.exe, so that what I see in VirtualDub (from the avs with the RGB to YV12 conversion) is what I get in the H.264 stream ?
In CS3, most filters cause conversion to RGB. There are some exceptions, like brightness used with fast color corrector (allow you to stay in YUV). Premiere CS3 uses ITU Rec.601 for the conversion to RGB, regardless of flags in the original stream. Even HD streams get converted using 601 (incorrectly, they should be using Rec.709). The exception is v210 input, which gets 709 treatment (and this is the workaround you had to do in the past for proper color for HD streams)
4. How do I determine the proper value for the --colormatrix parameter for x264.exe, so that what I see in VirtualDub (from the avs with the RGB to YV12 conversion) is what I get in the H.264 stream ?Last edited by poisondeathray; 20th Dec 2012 at 08:29.
Premiere RGB exports produce bad frames - is YV12 a good alternative?
By spicediver10191 in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 17:02 -
Convert YUY2 to RGB
By jrivord in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2010, 10:21 -
YV12 to RGB color problem
By wydesenej in forum Video ConversionReplies: 2Last Post: 30th Oct 2009, 07:42 -
Help with captured AVI: Vdub / HCenc / RGB / YUY2 / YV12
By Rinsin in forum Video ConversionReplies: 2Last Post: 13th May 2009, 18:57 -
DVD to DVD: YV12 to RGB to YV12, color problem ???
By cd090580 in forum RestorationReplies: 9Last Post: 24th Oct 2008, 10:16
