  1. I set the compilation to fit a BD-R but the end result is 23.5 GB which won't fit a BD-R. Is the calculation of multiavchd inaccurate sometimes or is it due to my background audio file size?
    Should I use custom size of 23000MB instead for future compilation? I notice if i click "fit all" a second time, a different compilation estimated size will be calculated.
  2. I also notice each time I click on "fit all", it deletes the transcode settings I have made earlier so I have to redo it again.
    Edit: I found a solution. I use notepad to automatically replace the settings so I don't have to manually click.
