Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 23 of 23
  1. Hi,
    I replaced my 9800GT card with a 640GT. The driver is the same (latest). Now the GPU feature is lost! In the preferences of vegas the card is listed correctly, when I hit the test-button of the Sony AVC, GPU is not available any longer. I use Vegas Pro 11 64 bit and Win 7 64 bit.
    Any idea?
    Oct 2005
    666th portal
    i'd try uninstalling vegas then reinstall. if it still doesn't work the card may be too new for pro11 and an update to pro12 may be needed.
  3. I reinstalled the video driver an Vegas. No success.
    Oct 2005
    666th portal
    iirc the older versions of vegas wanted nvidia cards that ended in xx70 of higher. it may see 640 and think it's too slow.
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I had the same problem after I upgraded my driver.
    To fix it, go to Device Manager, right-click the video card, and search for new drivers on the internet.
    Problem Solved! Guar-ahn-teed!
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Did you do a "Clean Install"?
  7. Searched drivers via Internet (device manager). No newer drivers found. No success.
    What do you mean with "clean install"? I have uninstalled Vegas and the Nvidia drivers and then reinstalled them.
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Go to nvidia website and download the driver you want to install, if you haven't already.
    Run the installer, and check the box "Option For Clean Install. This will reset whatever is causing the problem. Everything default. I had the same issue with this, and pulled my hair out for months. This solved it for me.
    I'm running a Toshiba Qosmio Laptop, and I couldn't get Cuda support in Vegas 12 Pro, also my graphics driver was preventing awakening from sleep. I don't know what I did to cause this, but I assume it was my settings, or something corrupted. I don't know, and don't care.
    I'm just happy now.
  9. Ran a clean install (latest Nvidia driver). No success.
  10. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Did you turn on GPU Acceleration in the preferences? In Vegas?
    When you start Vegas, it reads off what it's doing as it loads. Do you see it mentioning GPU Acceleration?
  11. I can see the card in the preferences. But the GPU test in the Sony AVC encoder fails.
  12. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    contact sony support. just my guess but the new gpu processors on the kepler cards are most likely not supported in the older versions of vegas.
  13. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I'm canceling my guarantee too.
  14. I have updated my VP 11 to 12. And now CUDA is available! Perhaps the GT640 is too new for VP11. Thank you all for your tips. Please excause my poor English.
    German:
    Ich habe mein VP11 auf 12 upgedatet. Und nun ist CUDA verfügbar! Vielleicht ist die GT640 zu neu für VP11. Danke euch allen für eure Hinweise. Bitte entschuldigt mein schwaches Englisch.
    May 2009
    Just curious, as I did not see any mention regarding it in the thread. Were you running the latest update (build 701 for Win7 64)?
  16. I was running build 701 (64 bit) on Win7 Professional 64 bit. There was a hint in the message of aedipuss, five posts above.
    Jan 2012
    Budapest
    Don't use the Vegas. Use the Adobe product family.
  18. Member
    May 2009
    I was thinking of upgrading the video card in one of my machines to one of the latest Nvidia cards, so I just wanted to be sure of that. If I have to also upgrade Vegas to do so, I think I'll hold off for a while.
  19. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Hi,
    I replaced my 9800GT card with a 640GT. The driver is the same (latest)....
    The way I understood this is that you were using the same driver.
  20. Yes, it is the same WHQL driver. It recognizes all new features of the GT640.
    Interesting: I still get the fastest results with CPU only. Rendering with the 9800GT is a little bit slower, and with the GT640 the slowest method.
  21. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the 9800gt was an older high end performance card, whereas the gt640 is a cheap low end card. the results are to be expected.
  22. I quess, you are right. It seems, that the memory bandwith is more important than the number of streaming units:
    9800GT: 112 streaming units, 256 bit memory bandwith
    GT640: 384 streaming units, 128 bit memory bandwith
    My 9800GT is cooled passively (long as a surfboard), the GT640 has a (much smaller) passive cooler, too. I don't want to use another fan in my silent PC. Can you recommend a high performance card for VP12, that is passively coold?
  23. Many review sites have found that GPU encoding doesn't scale very much with the power of the GPU.
    For example:
    in the case of GeForce and Radeon encoding, there’s no difference in speed between graphics cards costing 100, 170 or 330 euros. Quality is strictly identical from one card to another
    http://www.behardware.com/articles/828-27/h-264-encoding-cpu-vs-gpu-nvidia-cuda-amd-st...-and-x264.html
    And the quality is inferior to x264, even when x264 is using settings that are faster than GPU encoding (on fast CPUs).
