Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 90
  1. Thanks it works great. Do you know if it's possible to mux several h264 .ts files together and do you have the code for that please? At the moment I'm right-clicking on a file and selecting Send To then I select my batch file. If muxing several files together how would that work?
    In the same batch file I would also like to extract the aac (like you gave me the code for before).
    Do you know of any other muxers beside TSMuxer. TSmuxer is a bit fiddly as you have to add files one by one.
  2. What do you mean by "mux several h264 .ts files together"? Append them? Simultaneous streams?
  3. The Elgato only records into a 4GB max file size. So it ends up recording several files named 001, 002, etc. I need to combine them in alphabetical order into 1 file. If possible in the same batch file, after it's created the combined file, in additional I would also like the audio demuxed from that combined file into an aac file.
    I was wondering as well, I just noticed this: http://www.izitips.com/video-tips/how-to-join-merge-ts-files-together/
    Are there any downsides to that method?
  4. Originally Posted by VideoFanatic View Post
    TsMuxer is a command line program. Doesn't the GUI show you the command line it generates?
  5. No. Do you know how to do what I mentioned in post 33 please?
  6. Originally Posted by VideoFanatic View Post
    I tried using ffmpeg but got a file that didn't play properly. When I used COPY/B I got a file that was the size of all the TS files added up, but only the first segment played in most players.
  7. Banned
    Freedonia
    The only reliable way I know for sure to do that is to use VideoReDo (NOT freeware). It's an editor and you can use it to combine various clips into file. I just mention it because I know it works as I've done what you want to do with it. If you need a free tool, maybe someone else has another idea.
  8. VideoRedo has a bug where when you use the VideoRedo Joiner and the files had AAC 224 Kbps then the combined file will have 64 Kbps.
    I'm using TSSplitter. Seems to work fine but you still need to click the Sort button when dragging the files in which I will probably forget to do by accident at some point in the future.
    Don't suppose there's a batch file for TSmuxer is there where I can select a bunch of files to join then right-click "Send To" the batch file to combine the files?
  9. If you run tsmuxer without any arguments it will give you a list of options:
    Network Optix tsMuxeR.  Version 2.6.11. www.networkoptix.com
    tsMuxeR is  simple  program to  mux video to  TS/M2TS files or create BD disks.
    tsMuxeR does not use external filters (codecs).
    Examples:
        tsMuxeR <media file name>
        tsMuxeR <meta file name> <out file/dir name>
    tsMuxeR can be run in track detection mode or muxing mode. If run tsMuxeR  with
    only  one argument  then tsMuxeR  display  input track information  required to
    construct  meta  file.  If run tsMuxeR  with two arguments tsMuxeR start muxing
    or demuxing process.
    Meta file format:
    File MUST has extension .meta.  This file  define files you want to  multiplex.
    First line of meta file contain additional parameters that apply to all tracks.
    In this case the line should begin with the word MUXOPT.
    Following lines indicate a list of tracks  and their parameters.  The format is
    as follows:   <code name>,   <file name>,   <parameters>   Parameters are comma
    separated. Each parameter indicates the name and value.
    Example of META file:
    MUXOPT --blu-ray
    V_MPEG4/ISO/AVC, D:/media/test/stream.h264, fps=25
    A_AC3, D:/media/test/stream.ac3, timeshift=-10000ms
    In this example one AC3 audio stream and one H264 video stream are  multiplexed
    to BD disk.  Input file name can reference to elementary stream or track inside
    container.
    Supported input containers:
    - TS/M2TS/MTS
    - EVO/VOB/MPG/MPEG
    - MKV
    - MOV/MP4
    - MPLS (Blu-ray media play list file)
    Names of codecs in the meta file:
    - V_MPEGH/ISO/HEVC  H.265/HEVC
    - V_MPEG4/ISO/AVC   H.264/AVC
    - V_MPEG4/ISO/MVC   H.264/MVC
    - V_MS/VFW/WVC1     VC1
    - V_MPEG-2          MPEG2
    - A_AC3             AC3/AC3+/TRUE-HD
    - A_AAC             AAC
    - A_DTS             DTS/DTS-Express/DTS-HD
    - A_MP3             MPEG audio layer 1/2/3
    - A_LPCM            raw pcm data or PCM WAV file
    - S_HDMV/PGS        Presentation graphic stream (BD subtitle format)
    - S_TEXT/UTF8       SRT subtitle format.  Encoding MUST be  UTF-8/UTF-16/UTF-32
    Each track may has addition parameters.  Track parameters do not  have dash. If
    parameter value has several words, parameter must be enclosed in quotes.
    Common additional parameters for any type of track:
    - track             track number if input file is container.
    - lang              track language. MUST contains exact 3 letters.
    Additional parameters for audio tracks:
    - timeshift         Shift audio track to future (positive value) or to past.
                        Measured at milliseconds.
    - down-to-dts       Available only for DTS-HD tracks. Filter out HD part.
    - down-to-ac3       Available only for TRUE-HD tracks. Filter out HD part.
    - secondary         Mux as secondary audio.  Available for DD+ and DTS-Express.
    Additional parameters for video tracks:
    - fps               Video fps. If not defined, default value auto detected from
                        a source stream if present. If not, default value 23.976.
    - delPulldown       Remove pulldown from the track if exists.  This option lead
                        to fps change from 30 to 24 if pulldown exists.
    - ar                Override video aspect ratio. 16:9, 4:3 e.t.c.
    Additional parameters for H.264 video tracks:
    - level             Overwrite  level in the H264 stream.  Note:  option  update
                        headers only. The H264 stream may not meet the requirements
                        of a lower level.
    - insertSEI         If original   stream  does not contain  SEI picture timing,
                        SEI buffering period or VUI parameters,  then add this data
                        to the stream. This option is recommended for BD muxing.
    - forceSEI          Add SEI picture timing, buffering period and VUI parameters
                        to the stream. Rebuild data If data already exist.
    - contSPS           If original video doesn't contain  repetitive SPS/PPS  then
                        SPS/PPS will be added to the stream before  each key frame.
    - subTrack          Used  for  combined  AVC/MVC  tracks  only.  TsMuxeR always
                        demultiplex  such  tracks to separate  AVC and MVC streams.
                        This parameter defined reference to AVC part(if value=1) or
                        or to MVC part (if value=2).
    - secondary         Mux as secondary video (PIP).
    - pipCorner         Corner for PIP video. Allowed values: "TopLeft","TopRight",
                        "BottomRight", "BottomLeft".
    - pipHOffset        PIP window horizontal offset from the corner in pixels.
    - pipVOffset        PIP window vertical offset from the corner in pixels.
    - pipScale          PIP window scale factor. Allowed values: "1", "1/2", "1/4",
                        "1.5", "fullScreen".
    - pipLumma          Allow PIP window to be transparent. Transparent colors  are
                        lumma colors in range [0..pipLumma].
    Additional parameters for PG and SRT tracks:
    - video-width       The width of the video in pixels.
    - video-height      The height of the video in pixels.
    - fps               Video fps.  Recommended  to  define this parameter for more
                        carefully timing processing.
    - 3d-plane          Parameter  defines  number  of  the '3D offset track' which
                        placed  inside  MVC  track.  Each message has individual 3D
                        offset. This information  stored  inside 3D offset track.
    Additional parameters for SRT tracks:
    - font-name         Font name to render.
    - font-color        Font color. Color can be defined in hexadecimal or  decimal
                        format. If color 24 bit long  (for instance 0xFF00FF)  it's
                        define RGB components.  IF color 32 bit long  (for instance
                        0x80FF00FF) it's define ARGB components.
    - font-size         Font size in pixels.
    - font-italic       Italic display text.
    - font-bold         Bold display text.
    - font-underline    Underlined text.
    - font-strikeout    Strikethrough text.
    - bottom-offset     Distance from the lower edge while displaying text.
    - font-border       Outline width.
    - fadein-time       Time in ms for smooth subtitle appearance.
    - fadeout-time      Time in ms for smooth subtitle disappearance.
    - line-spacing      Interval between lines. Default value 1.0.
    tsMuxeR  supports  addition  tag inside  SRT track.  The syntax  and parameters
    coincide with HTML: <b>, <i>, <u>, <strike>, <font>. Default relative font size
    (used in these tags) - 3.  For example:
    <b><font size=5 color="deepskyblue" name="Arial"><u>Test</u>
    <font size= 4 color="#806040">colored</font>text</font>
    </b>
    Global addition parameters placed in the first line of the META file  (MUXOPT).
    All parameters in this group started with two dashes:
    --pcr-on-video-pid  Do not allocate separate PID for PCR, use an existing video
                        PID.
    --new-audio-pes     Use bytes 0xfd instead of 0xbd for AC3, True-HD, DTS and
                        DTS-HD. Parameter is auto activated for BD muxing.
    --vbr               Use variable bitrate.
    --minbitrate        Sets the lower limit of the vbr bitrate.  If the stream has
                        a  smaller bitrate  then NULL  packets will be inserted  to
                        hold the limit.
    --maxbitrate        The upper limit of the vbr bitrate.
    --cbr               Muxing mode  with a fixed bitrate.  Options --vbr and --cbr
                        should not be used together.
    --vbv-len           The  length  of the  virtual  buffer  in milliseconds.  The
                        default value  is 500.  Typically, this  option  is used in
                        together with --cbr. The parameter is similar to  the value
                        of  vbv-buffer-size  in  the  x264  coder,  but  defined in
                        milliseconds instead of kbit.
    --no-asyncio        Do not  create  a separate thread  for writing.  Also, this
                        option  disable  flag  FILE_FLAG_NO_BUFFERING  for writing.
                        Deprecated option.
    --auto-chapters     Number.  Insert a chapter every <nn> minutes. Used only for
                        BD/AVCHD mode.
    --custom-chapters   A semicolon delimited list of string in format hh:mm:ss.zzz
    --demux             In this mode selected audio  and video tracks are stored as
                        separate files instead of muxing. utput name must be folder
                        name.  All selected  effects  (such as change  of level for
                        h264) are processed.  When demux,  certain types  of tracks
                        always get changed on storing into a file:
                        - Subtitles in a Presentation Graphic Stream  are converted
                          into sup format.
                        - PCM audio are saved as WAV files.
    --blu-ray           Mux to BD diks. If output file name is folder,  bluray disk
                        is created as folder on HDD.  For BD3D disks ssif files are
                        not  created at  this  case.  If output file name  has .iso
                        extension, then BD disk is created as image file.
    --avchd             Mux to AVCHD disk.
    --cut-start         Trim the beginning of the file.  Value should be  completed
                        with  "ms"  (the number of milliseconds),  "s" (seconds) or
                        "min" (minutes).
    --cut-end           Trim  the end of the file.  Value should be  completed with
                        "ms" (the number of milliseconds), "s" (seconds) or "min"
                        (minutes).
    --split-duration    Split output to several files.The time specified in seconds
    --split-size        Split  output to several files.  Values  should be  written
                        using one of the following postfix: Kb,kib, mb,mib, gb,gib.
    --right-eye         Use base video stream for right eye. Used for 3DBD only.
    --start-time        Timestamp of the first video frame. May be defined as 45Khz
                        clock (just a number) or as time in format hh:mm:ss.zzz
    --mplsOffset        The number of the first MPLS file.  Used for  BD disk mode.
    --m2tsOffset        The number of the first M2TS file.  Used for  BD disk mode.
    --insertBlankPL     Add extra  short playlist.  Used for cropped video muxed to
                        BD disk.
    --blankOffset       Blank playlist number.
    --label             Disk label for muxing to ISO file.
    --extra-iso-space   Allocate extra space  in 64K units  for ISO  disk  metadata
                        (file and directory names). Normally, tsMuxeR allocate this
                        space automatically. But if split condition generates a lot
                        of small files, extra ISO space may be required to define.
    There's also information at: http://forum.doom9.org/showthread.php?t=168539
  10. Thanks, I'll have to look at that another day. I've gone back to VideoRedo which has a bug where when you use the VideoRedo Joiner and the files had AAC 224 Kbps then the combined file will have 64 Kbps. So instead I've saved as an MP4 with WAV. I've then tried to use this script
    "X:\Portable Installations\ffmpeg-2014 May 14-git-72dcd48-win64-static\bin\ffmpeg.exe" -i %1 -acodec flac -ac 2 -compression_level 5 "%~d1%~p1%~n1.flac"
    "X:\Portable Installations\ffmpeg-2014 May 14-git-72dcd48-win64-static\bin\ffmpeg.exe" -i %1 -vcodec copy -acodec ac3 -ac 2 -ab 128k "%~d1%~p1%~n1.AC3.ts"
    pause
    I want the script to mux the MP4 to a TS file (but re-encode the audio to AC3). Also I want a separate Flac file. I can get the flac file OK but the video conversion fails and it shows a red message saying "h.264 bitstream malformed, no startcode found, use the h264_Mp4toannexb bitstream filter (-bsf h264_mp4toannexb).
    Do you know what the correct script is I should use please?
  11. Ok, I worked out how to use tsmuxer to append multiple ts files. Here's a batch file onto witch you can drag/drop up to 9 source files:
    echo MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 >built.meta
    echo V_MPEG4/ISO/AVC, %1+%2+%3+%4+%5+%6+%7+%8+%9, insertSEI, contSPS, track=100 >>built.meta
    echo A_AAC, %1+%2+n3+%4+%5+%6+%7+%8+%9, timeshift=-466ms, track=101, lang=USA >>built.meta
    "G:\Program Files\TsMuxer\TsMuxer.exe" built.meta appended.ts
    pause
    The output file is appended.ts. You might want to delete built.meta at the end of the script. Change the path to tsmxuer.exe to reflect where it is located on your system.
    Note that this leaves extra + signs in the file spec when less than 9 files are appended. For example, if you only drag 2 files onto it the file spec will look like:
    "file1.ts"+"file2.ts"++++++
    Fortunately, tsmuxer doesn't seem to mind that.
    Another issues is the audio delay time. It will vary with the source files but the batch file uses a constant.
  12. The audio delay sounds a bit worrying? When I used the TSMuxer GUI I never get a delay.
    Can you help with post 40 please as I've already converted some of my files to MKV with WAV but I shall try the TSmuxer batch tomorrow.
  13. Originally Posted by VideoFanatic View Post
    I don't think I have antything to add.
  14. Why do you need TS files? Can't you use MKV or MP4 instead?
  15. No because I'm using Avisynth to re-encode them so they need to be .ts for use with DGIndexNV.
    The TSMuxer script you made, I'm a bit worried that it will cause an audio delay. Why would it cause an audio delay?
  16. Originally Posted by VideoFanatic View Post
    It causes an audio advance (a negative delay is an advance) because of the command "timeshift=-466ms" in the meta file. But that was the timeshift of the source videos I was using, the same value tsmuxergui used. TS files usually have an audio timeshift like this. You just need to set the value for your particular sources. If you record with the El Gato with the same settings all the time I think the timeshift will be the same in all your recordings. I have a collection of test recordings made with the El Gato with different settings and the timeshift runs from about -300 to -500 ms.
  17. Can't I just use the script without the timeshift=-466ms. Is it really needed?
  18. All your source files probably have a timeshift. Check them. look at the meta info created by tsmuxergui. If you remove that timeshift the results will be out of sync.
  19. Originally Posted by jagabo View Post
    pause
    I selected 2 files, right-clicked on 1 of them then selected Send To (the batch file I created). Used your script as is and the cmd window seems like it's doing stuff but no file is created. Is it supposed to create the file in the same directory as the source files?
    I tried again deleting the built.meta from the 2nd last line but the script just finishes immediately without doing anything. How do I get it working?
    I was wondering as well if it's possible to use FFMPEG in the same batch file so that once the files are joined into 1 file, FFMPEG will then mux to .ts and re-encode the audio to AC3 and also demux the original AAC into a separate AAC file?
  20. Try changing the output filename to: "%~d1%~p1.appended.ts".
    The default folder varies depending on the version of Windows. Your files may have gone to the SendTo folder or maybe c:\Windows\, c:\Users\username\, or somewhere else. Just search for appended.ts.
    Also be careful about the file order. Drag the first file of the list to the batch file. Otherwise the files may not be in the order you want.
  21. I'm using this script but no file is created. By the way am I still supposed to select all the files then just right-click on the 1st file and Send To?
    "X:\Portable Installations\tsMuxeR_2.3.2(b)\tsMuxeR.exe" %~d1%~p1.appended.ts
    pause
  22. You left out the name of the meta file on the tsmuxer command line.
    Yes, select all the files, then right click on the first and SendTo...
  23. This is was I'm using. Is the 2nd last line now correct? If so, it's still not working:
    "X:\Portable Installations\tsMuxeR_2.3.2(b)\tsMuxeR.exe" built.meta %~d1%~p1.appended.ts
    pause
  24. Change the tsmuxer line line to:
    "X:\Portable Installations\tsMuxeR_2.3.2(b)\tsMuxeR.exe" built.meta "%~d1%~p1appended.ts"
  25. Thanks, it's working now.
    The files all have the last 5 characters in the file name like this:
    _0001
    _0002
    Is there any way to get TsMuxer to mux them in alphabetical order as it would be easy to drag them in the wrong order.
  26. Is there any way to add an audio noise that happens when the file have finished muxing in the cmd?
  27. Originally Posted by VideoFanatic View Post
    In theory you could build a list of files from the command line, sort the list, then import the sorted list to the meta file. But I don't know all the details off the top of my head.
    You play an audio file by specifying it in the batch file:
    "C:\Windows\Media\Windows Notify.WAV"
    That will spawn the default audio player to play it.
    Or you can echo CTRL+G (the ASCII bell character)
    https://en.wikipedia.org/wiki/Bell_character
    But Notepad won't let you type in CTRL+G. I typed in "echo G" then used a hex editor to change the G (hex 47) to CTRL+G (hex 07).
  28. Thanks. Works great and the delay doesn't seem to be an issue. I'll try the audio notification tomorrow. I'm just going to use your TSMuxer batch script to join the files then edit in VideoRedo then mux the video + convert to AC3 with FFMPEG with this batch file you gave me:
    "X:\Portable Installations\ffmpeg-2014 May 14-git-72dcd48-win64-static\bin\ffmpeg.exe" -i %1 -vcodec copy -acodec ac3 -ac 2 -ab 384k -af volume=+6dB "%~d1%~p1%~n1.AC3.ts"
    pause
    On some of my videos the audio is quite low. That's just the default volume that my satellite box and it's programmes have and you can't change the output volume of the box or change the volume in the Elgato. To listen to it clearly at a decent volume with headphones you have to turn the volume up high on the headphones which causes hiss. I know you can specify how much you want to amplify the audio by as underlined in the above script, however I would need to guess how much to amplify by for each video which could cause clpping. Is there anyway in the script to amplify to 0dB which is the safest maximum volume and to do it without causing clipping?
    I've noticed that some programs will still amplify a file which is already loud enough causing the volume to go way too high and it causes clipping.
    My satellite freeview box amplifies to 0dB without causing problems so I was wondering if it's possible to do it in the script.
  29. Member vhelp's Avatar
    Mar 2001
    New York
    so, thanks to this thread, i discovered that my elgato splits the videos. i never really paid attention to that aspect of recording video, back when i was recording the recent winter olympics samulataniously with the elgato and hauppauge hdpvr. however, i tried to no avail to use ffmpeg and mp4box to get copy the videos on my win7 prem i3 laptop but it took soo long that i couldn't tell if it were working or i was not using correct parameters.
    so, then i decided to take the hdd over to my amd dual core win xp home desktop machine and try the ffmpeg / mp4box again. mp4box would not do what i want. i tried the -add and -new combination, including the -cat param and it would not do anything except sit in the taskmgr. then i treid ffmpeg and it seemed to be working but was taking a really long time that after 20 minutes, i stopped it, but the video would not play.
    so then i decided to try my custom made filejoiner app (i posted somewhere on here a long time ago) and that worked, however, it was also slow. it took 12 minutes to join two 4096gig files into one 8192gig video.ts file. that played w/out problems. but that is still a long time to join files. and that was only two files. i have a number of folders that contain four or five 4gig files like that. that would take an hour or longer to join.
    so, natually, i am curious.
    @ videofanatic, how long are your joins taking you ?
    my path goes like this, using two new usb3 hdd's: [diskI] 1tb hdd usb2 -> [diskJ] 1tb hdd usb2 -> video.ts
  30. Originally Posted by vhelp View Post
    USB2 is slowing you down.
    My earlier script that uses TsMuxer took about 110 seconds to append two 4 GB files to one 8 GB file on the same drive. From one drive to another took about 100 seconds. Both were internal SATA drives.
