What extra cables/connections do I need to make this recording work? I have a scart connection from DVD to TV which plays films. When I try to record I just get blank output. Thanks
You need to put the recorder between the video source and the TV. Or you need to use the DVD recorder's internal tuner (if any). If you're using the TV's internal tuner and your TV doesn't have "monitor out" you are out of luck.
Toshiba LCD/DVD Hack
By mebrat in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 10:55 -
Toshiba d-vr17-k-tb
By Live2WinForever in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Sep 2010, 12:48 -
Toshiba D-VR17 - Unable to finalise discs! Help please?
By colinb1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Mar 2010, 12:02 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
PC to Samsung LCD Again
By southcraven in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2009, 21:15
