ok bought a dvd rom drive (a lite-on) and i'm experimenting with ripping the fast and the furious dvd... i downloaded several different tools like smartripper 2.41, dvdx 1.6, dvd2avi 1.76 and i made hardcopies of the guides... i rip the dvd with smartripper, no problem there! but when i try to convert in dvdx or dvd2avi it starts 10 minutes into the movie?!?!?!?!
i expirence the same problem with swordfish but not with snatch and blade?!?!?
am i doin' sommethin' wrong or have others encountered the same problems???
convert?
dvd2avi is only a frameserving tool so you can frameserve the vobs to tmpgenc to encode...
in dvd2avi, you should only be making a project file, not .avi file..
TV capturing n Rippin using VduB
By SMChoice in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2009, 11:39 -
audio rippin question
By completetech in forum AudioReplies: 2Last Post: 5th Apr 2009, 10:04 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
