Results 1 to 1 of 1
  1. Since mplayer(2) itself does not detect if a source is interlaced or not I started a small project to analyse a source with mplayers pullup filter.
    basically it collects the output of :
    mplayer2 -noframedrop -lavdopts threads=8 -speed 100 -v "path to input" -nosound -vo null -ao null -nosub -vf pullup
    and:
    mplayer2 -noframedrop -lavdopts threads=8 -speed 100 -v "path  to input" -nosound -vo null -ao null -nosub -vf pp=lb,pullup
    which both output stuff like:
    V:  17.9 537/537 156% 513%  0.0% 0 0 100.00x
    affinity: .0++1..2+.3.
    breaks:   .0..1..2|.3.
    duration: 2
    per frame.
    Depending if there's a + or a ++ between the numbers in affinity it counts light (+) and strong (++) affinities, whether or not there is a break and how the duration changed.
    Looking at the affinity, breaks and duration changed it than decides if the content is:
    a. normal interlaced
    b. telecine
    c. field-blended
    d. mixed progressive/interlaced
    content.
    I know that this can't replace detection with your own eyes using (avisynth and separate fields&co), but it might be a nice gimmick for those that don't know how to use avisynth.
    Since I normally only have telecine or interlaced content I play with (+ I'm a n00b when it comes to interlacing&co) this decision isn't really tested well.
    -> Would be nice if some of you could test it (drag&drop a file into it, than press Analyse) with some of your content and if you think/know that the tool is wrong, please post a small sample of the content which shows the problem and tell me what it should have detected.
    Cu Selur
    Ps.: Uploaded source to github: https://github.com/Selur/MPlayerInterlaceDetection
