Ok so I'm trying to create a bootable Windows 7 System Repair disc, so I can put pc image onto a new drive. I have treid 3 times 2 on cd 1 on dvd and none have created a bootable repair disc.I'm using the Windows 7 Create a System Repair disc wizard. When I boot from the newly created cd, I get an error Non-System disk or disk error, replace and press any key, I try the other cd and dvd, I get ERROR: No boot disk has been detected or the disk has failed.
If I open the cd in explorer I can see the files are on the cd:
Boot (folder)
efi (folder)
sources (folder)
bootmgr.efi (file)
What We Do In Life, Echoes In Eternity.... -
You need to create both "repair" and "system image" discs ... boot from the repair, choose option to restore from an image file, eject repair disc and insert backup image disc and away you go ... that's how its done
I've already created the System Image Discs (4 dvds), and the Windows System Repair disc (cd). The issue is after creating the repair disc (3 separate tries all successful by windows) I am unable to boot from the repair disc. (But I can see that the files have been created on the repair disc) When I put any of the newly created repair discs into the cd/dvd drive I get a black screen with error Non-System disk or disk error, replace and press any key
First thing to do is grab a copy of macrium reflect and an external hd with plenty of space and make a master backup ... in case one of those windows master image discs go pear shape.
If you use imgburn and insert the repair disc, click create an image file from disc ... wait ... then in next pane it should indicate if its bootable or not.
If image burn identifies the boot disc as not bootable, you should be able to download an iso (32bit or 64bit) ... from microsoft which is where I got one for a client a while back and burn it to cd ... make sure you use quality media if your optical drive has done a lot of work ... Ive seen success message where discs failed before and it comes down to wear and tear.
Beware when booting ... not all systems are equal and to avoid bugs I generally disable hd boot option when doing image backup restore and re-enable it once completed. -
Any Windows 7 install DVD have include System Repair option same as in System Repair disc:
for more info: http://www.tomshardware.com/news/win7-windows-7-mbr,10036.html -
How to Repair Internet Explorer 6 in Windows 2000
By edong in forum ComputerReplies: 46Last Post: 16th Mar 2013, 07:59 -
Want to repair Windows xp - facing several issues
By GLE3 in forum ComputerReplies: 8Last Post: 25th May 2011, 16:29 -
How Extensive Is Windows System Restore(XP Pro)?
By hech54 in forum ComputerReplies: 10Last Post: 11th Aug 2010, 23:55 -
System Restore Not Working
By Squid_uk in forum ComputerReplies: 7Last Post: 19th Nov 2009, 08:43 -
Asfbin -rfk - wmv vcm not found/working on Win7 x64?
By tiesto in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2009, 14:12
