  1. I have avi files that use Lagarith or Huffyuv lossless codecs. The goal is to play them on the iPad. I've tried HandBrake and Avidemux but couldn't open the files.
    I tried to use Avisynth with the command AviSource("c:\path\video.avi") but neither Handbrake nor Avidemux could open the script.
    How do I work with these avi files without transcoding to another codec first?
    Oct 2005
    666th portal
    do you have the codecs installed on your computer? can you play the avi files?
  3. Yes I have the codecs and can play the files. I need a way to convert the avi to m4v/mp4 directly.
    Tried a ffmpeg frontend like winff? Use the ipad preset.
  5. Originally Posted by shun View Post
    Neither Handbrake nor AviDemux can open AviSynth scripts directly. With AviDemux you can use the included AvsProxy program, then File -> Connect to AvsProxy in AviDemux.
    http://tellmewhy.xooit.eu/t806-AVIDemux-FAQ.htm
  6. Thanks guys, those methods worked.
