  1. Just upgraded to the newest version...love the idea of DE. I am having some issues with the DE and even getting jobs to complete properly. Thanks in advance to those who post.
    M:\>"C:\Program Files (x86)\RipBot264v1.17.3\tools\bepipe\bepipe.exe" --script "import(^M:\Temp\RipBot264temp\job1\job1.avs^) " | "C:\Program Files (x86)\RipBot264v1.17.3\Tools\fhgaacenc\fhgaacenc.e xe" --profile lc --cbr 320 --adts --ignorelength - "M:\Temp\RipBot264temp\audio.aac"
    BePipe by dimzon
    Script used:
    # BEGIN
    import("M:\Temp\RipBot264temp\job1\job1.avs")
    # END
    Scanning for Audio Stream...
    Found Audio Stream
    Channels=6, BitsPerSample=16, SampleRate=48000Hz
    Writing Header...
    Writing Data...
    0%
    Done!
    M:\>"C:\Program Files (x86)\RipBot264v1.17.3\EncodingClient.exe" "M:\Temp\RipBot264temp\job1\job1_EncodingClient.me ta"
    M:\>"C:\Program Files (x86)\RipBot264v1.17.3\tools\mp4box\mp4box.exe" -tmp "M:\Temp\RipBot264temp" -add "M:\Temp\RipBot264temp\video.264":name="video" -fps 23.976 -add "M:\Temp\RipBot264temp\audio.aac":lang=eng -mpeg4 -new "C:\Users\<username_removed for post>\Desktop\video.mp4"
    Cannot find file M:\Temp\RipBot264temp\video.264
    Error importing M:\Temp\RipBot264temp\video.264:name=video: Requested URL is not valid or cannot be found
    Elapsed Time: 00h:02m:02s
    Redding, California
    Open the 'Ripbot264.ini' file and under settings, change "StoreTempFilesin=AUTO". It will select the largest partition to use.
    Or you can select a drive to use as a temp.
  3. Originally Posted by Megahurts View Post
    Did...made no difference. The error / log is the same. Finishes in a minute or so.
  4. Originally Posted by jagabo View Post
    What's DE?
    Distributed Encoding...
  5. Originally Posted by clefus View Post
    What's DE?
    Ah. Thanks.
