I have just tried to convert SHREK from dvd to vcd, used DVDDecryptor, then DVD2AVI, then Tmpgenc. The resulting MPG file when played on the computer before burning to disc has the audio playing about 800 ms fast all through the movie. I've never had this problem before, have I forgotten to do something?
in dvddecryptor, goto options and then enable Multi-angle processing....try again
shrek has multi-angles during it's intro, if not taken out, they will cause outta sync audio and repeating frames -
I've seen this before, and a lot of times it's just a problem with the way Windows Media Player handles the file.
In other words, when I watch the movie in Windows Media Player it is out of sync, but when I burn the movie to a CDR, it plays fine in my DVD player.
Also.....once I had a 1.6GB (90minute movie) MPEG2 file which was out of sync when playing in Win Media Player, then I cut the MPEG2 in half so I could burn it onto 2 CDRs. I tried to play each half of the MPEG2 in Win Media Player, and to my surprise both MPEG2's were in sync!!!
Go figure that one out!!
My advice, burn it first and see if it is really out of sync before you spend another 1.5 lightyears encoding it!!
Let me know if it works....~Urbs~
DVD Conversion Lip Sync Issues
By waykins in forum DVD RippingReplies: 4Last Post: 4th Jun 2011, 09:23 -
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 16:36 -
Formula for NTSC to PAL lip-sync
By macnab in forum Video ConversionReplies: 4Last Post: 11th Aug 2010, 10:16 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 04:47 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 15:53
