  1. Member walruss's Avatar
    Sep 2012
    Norway
    Since I have installed winrar on my Windows 7 (x64), all JAR files just won't work anymore. I'm trying to start BDSup2Sub.jar
    I googled it and found: With the Java runtime installed, the JAR can be started by double clicking on it. Alternatively, you can start it from the command line via: java -jar BDSup2Sub.jar or javaw -jar BDSup2Sub.jar in CMD.
    But I don't know how to do this in Windows 7 or in CMD..
    Have you tried right click on the jar and see if can change it so it starts with java (javaw.exe) ?
    See also http://stackoverflow.com/questions/8511063/how-to-run-jar-file-by-double-click-on-windows-7-64
  3. Member walruss's Avatar
    Sep 2012
    Norway
    Yes, nothing happens. Tryed to remove java and reinstall it but It didn't help.
    Then start a command line box. Start menu->Run and type in cmd and enter.
    Type then java and enter and see so it runs.
    Type then
    java -jar c:\folder\BDSup2Sub.jar
    Replace the folder where you have bd2subpsi2upsduppspsupsppusp.ar
  5. Member walruss's Avatar
    Sep 2012
    Norway
    Type then
    Yes that worked just fine.
