Hey.
When I load hebrew subtitles to SW4, it shows gibberish even after changing the charset.
I know the subs work because they do display well with VLC.
Here's the file:
https://dl.dropbox.com/u/9202337/Breaking.Bad.S05E01.720p.HDTV.x264-IMMERSE.srt
Can you tell what's the problem?
I don't know how to do it in SW4, but in Subtitle Edit you can try this: File -> Import subtitle with manually chosen encoding...
I prefer utf-8 and think ANSI is a big hack - here's a long but nice explanation: http://coding.smashingmagazine.com/2012/06/06/all-about-unicode-utf8-character-sets/ -
Thank you.
SE works.
Off topic, I find working with SE a little less convenient. Doesn't have the Shift+H/N feature. -
Just moves the selected lines 0.1 seconds late/early.
In SE you have to set a time you want to move the subs, click enter, check if it's ok etc.. -
OK, thx for the info.
I mostly use the waveform/spectrogram in SE, and then ctrl+shift+left-click to set the start of current subtitle + offset the rest.
In SE (the new 3.3 at least) you can set shortcuts for moving 100ms forward/back: Options -> Settings -> Shortcuts:AdjustLast edited by Nikse; 16th Dec 2012 at 08:56. Reason: Fixed shortcut
Convert pac subtitle to something that I can open in Subtitle workshop
By Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 20:49 -
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Add Subtitle with Arabic charset to m2ts blu-ray (BDMV)
By zetallico in forum SubtitleReplies: 3Last Post: 17th May 2010, 16:12 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
