What do I do if I want to cut clips from different video files, and then stitch them together for a new file?
Tell me if this is right:
Lets say I'm cutting clips from 2 YouTube mp4 files, so I cut out the clips in AviDemux, and make sure to select the output video and audio to "copy" and the file container to mp4, then save the clips with .mp4 extension. Correct?
My main concert is I want the clips to not be reconverted during cutting and stitching... I want to keep the video same as the original. Would the method I described keep the original video without any reconversions?
yes, but the cut points have to be on keyframes - you're cuts won't necessarily be frame accurate (use the "<<" and ">>" buttons in the GUI to navigate to nearest keyframe)
Another question:
I opened an mpeg-ts file of a home movie (which has .mts extension), and tried to trim the video and save it. I set the container to Mpeg TS Muxer (ff) and audio and video outputs to copy. I made sure to put it on key frames. Then I tried to save it as a .mts file, but I got an error message and nothing saved.
Did I do something wrong? Did I type a wrong file extension? -
avidemux
By BaPW in forum EditingReplies: 1Last Post: 3rd Apr 2012, 03:44 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
avidemux....
By sgbd in forum Video ConversionReplies: 1Last Post: 3rd Sep 2010, 07:06 -
Avidemux 2.5.2
By shivz@013.net in forum EditingReplies: 2Last Post: 16th Jan 2010, 08:40 -
AviDemux....again...
By diablo_jones999 in forum Newbie / General discussionsReplies: 5Last Post: 10th May 2008, 08:31
