    Dec 2002
    Is it possible using an editing/conversion program to slow the film down without any screen noise etc etc and re-record it at that speed. I have put lots of vehicle action clips onto my Ipad and want to slow down the action.....obviousley the easy option is to use a player that can do this, But i like to try and use a program to do this, so that the video file is already playing in a slower motion, so that I can just PLAY the file normally. I hope this makes "some" sense
    May 2003
    Peterborough, England
    Open Windows Movie Maker, import your file, drop it into the timeline, rightclick the clip, select video effects, add play half speed, save the file.
    Dec 2002
    Thats great.....However The video files I import into WMM show up on the thumbnail box fine, but when I try to play the the screen goes GREY, what format should the video file be in to work properly in WMM...thanks for your help
    Mar 2011
    Nova Scotia, Canada
    Unfortunately windows media programs stink when it comes to compatibility with other codecs. Jeez, you can't even play flac's in wmp without installing a 3rd party codec. Which neither I or microsoft recommend.
    Also unfortunately, I don't have any other suggestions, but I'm sure someone else will.
  5. iMovie app. Right on your ipad $5
    Pinnacle Studio for iPad $13
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    One day you'll be able to get pro apps on iPad.
  7. You gotta love that Budwzr!
