I have been a big fan of Potplayer for a long time but there is just one setting that I can never figure out. It exists as default in all other players I have used.
So the issue is that after minimizing Potplayer when I double click on another file (I have the "PLAY THE CLICKED FILE" option checked under the Multiple launching),it starts to play but the window is still minimized. I mean usually for all other media players the double clicked files should pop open on top always.
Does anyone have a solution to this?
Thanks!
				Results 1 to 15 of 15
	anyone knows the answer? i mean i thought it is pretty natural for everyone to have this setting, cuz it exists in all other media players...thx
	I normally don't post (or like) "me too" or "bump" replies, but in this case I decided to do it anyway.
 I have the exact same problem with Potplayer and I can't believe that unloaded1 and me are the only two Potplayer users who have come across of this bug (it surely can't be a feature, right?)
 Does anyone have any clue about how to fix it?
 Thanks!
	I don't believe it's a bug because my Win 7-32 installation doesn't exhibit the behavior you describe. The second (third, fourth, etc.) open in a new window.
	Thanks for your reply, OldGeek.
 But we (unloaded1 and me) are describing a different situation: we don't want to have multiple instances of PotPlayer when we click on new files, we just want the current (and minimized) instance of Potplayer to start playing the file we just have double clicked on. There is a preference for that in PotPlayer's options: "General" -> "Multiple Launching" -> "Play the clicked file" (instead of "Launch multiple PotPlayer").
 What currently happens is that, when you have a file open on PotPlayer and the program is minimized, double clicking on a new file does indeed start playing the new file on PotPlayer but (and here's the bug) PotPlayer doesn't restore the window. So the new file is playing, but you can't see it because the window stays minimized. I hope I could explain it clearly.
	OK, I understand, and you are correct. Mine behaves the same way
	So I guess it is a default setting in Potplayer...
 does anyone know if that setting can be changed? or simply a reg file that can be applied to fix it?
 i mean i wouldn't call it a bug, but it's just a personal preference that I have developed from all other media players lol.
	Since you minimized the player, that is your instruction, and the player conformed. Now, you are requesting the player 'play' another file. Why should it now return to the screen - you wanted it minimized.
 The developer could add an option, "Return to screen when minimized and another file is selected"
 Cheers.
	No, not really. That's not how programs work on Windows. When a program is minimized and you double click on a file that is set to be opened by that program, the program's window is restored. For example, if I have Word minimized on the taskbar and I double click on a .doc file on Windows Explorer, Word is restored in order to show me the file.
 Test it for yourself and see.
 It's PotPlayer's fault, not ours
	You're right. I didn't choose a good example with Word.
 A better example is a picture viewer. I tried it with Irfanview, setting it to only allow one instance of the program, and IrfanView behaves as (I think ) it should: when it's minimized, and I double click on a graphic file, the program window is restores to normal size and I can see the picture. ) it should: when it's minimized, and I double click on a graphic file, the program window is restores to normal size and I can see the picture.
 It's understandable that audio players don't behave that way (I tried the same experiment as yours with AIMP and got the same results, it stays minimized), because in audio players you don't need to restore the window to "see" anything. It's the sound that's important. OK, maybe you want to check the equalizer or the song information, but that's secondary.
 Back to video players, I finally tried the experiment with other two programs: KMPlayer (the predecesor of PotPlayer), and SPlayer. They both restore the window when they are minimized and a new video file is opened. What unloaded1 said in the very first post is true: I think every other video player behaves that way (restoring the window instead of staying minimized). It's a mystery, and an annoying one, why PotPlayer doesn't do that.
	The only thing I can think of, is that the developer assumes the user is viewing video (the intended use of a video player), and that the program has focus on the display.
 I have been using PP for quite some time, both for video and to display content from my TV tuner card. Just the other day, I used it to capture video from a VHS tape. It's a great program!
	I found this thread while researching this same issue. Did anyone find the fix to this?
  SMPlayer not remembering to start maximized (different that full screen)By natalia25 in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2012, 10:26
  mouse double click is not responsive during recordingBy George2 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2009, 01:56
  mouse double click is not working quite good during screen recordingBy George2 in forum ProgrammingReplies: 5Last Post: 28th May 2009, 20:07
  No Mouse Double Click Button in Windows 7 ?By wulf109 in forum ComputerReplies: 2Last Post: 22nd May 2009, 13:59
  Rebuilding VLC under Windows. Have to get rid of fullscreen on double-clickBy lagu2653 in forum ProgrammingReplies: 3Last Post: 20th May 2008, 15:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
