To be honest, Im not sure if this problem started when I updated my iTunes (quicktime update was included, I think) or was it present before, but lately Ive been getting semi-transparent grey color over every video file I play.
The only time I can actually see the footage is when I choose windowed renderer in the output menu.
I have a 1080p monitor, so if I open some older video file and stretch it to full screen in MPC, it doesn't smooth out anything...it pixelates.
Im running W7x64, is there a way I can clean up my codecs, fix this issue and give MPCHC a clean install without grey and pixel problems?
				Results 1 to 9 of 9
	Reinstall windows.
 No, I have no good tips....other than try different output renderers in the settings.
	I've seen this problem with mixing renderer 9 (windowless) in XP. Never got to the bottom of it,
 just deleted mpc-hc's preferences out of the registry and allowed it to start fresh.
 That particular renderer is the "recommended" renderer for XP, according to MPC-HC.
 I'm running version 1.6.4.6052, and so far it has not re-occurred.
  MPC HC x64 1.6.1.4235 - How to display MKV Subtitles?By Innomen in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2012, 22:07
  MPC HC x64 double images/videos since svn 1503? (pix attached)By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2010, 08:30
  How to install MPC X64 and all filtersBy Frankiecima in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2009, 07:51
  Best codecs for Vista x64By dbone1 in forum Software PlayingReplies: 0Last Post: 31st Dec 2008, 11:24
  Will my video programs, codecs, etc, still work with Windows X64?By HartsVideo in forum Software PlayingReplies: 15Last Post: 5th Sep 2008, 14:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
