i read a month or so ago in pc magazine of a program called "ramdisk xp". basically what it does is create a virtual drive from your ram.. so per se you had 3 gigs of ram, you could allocate 2 gigs as a virtual drive.. which you could capture video to .. without any fears of your harddrive's slowness causing dropped frames, meaning you could also capture at a higher bitrate... has anyone tried this? i only have 256mb of ram on this system, but i'm building a new one soon, and am defienetly considering starting off with a 1gb ramdus ram module, and adding 2 more when i can afford it...
nothing in stone.. just a thought...
Results 1 to 1 of 1
Good Long Range Wireless Keyboard/Mouse Solution
By greymalkin in forum ComputerReplies: 3Last Post: 1st Apr 2012, 18:49 -
Looking around for a solution to this problem.
By chrisyroid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th May 2010, 08:44 -
4:3 and 16:9 on same DVD - solution
By sergem1 in forum Authoring (DVD)Replies: 6Last Post: 15th Jan 2010, 02:03 -
Need Streaming Solution
By jadude in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2007, 18:17 -
Need new (cheap) capture solution-what to get? Are TV tuner cards any good?
By wickeddvine in forum Capturing and VCRReplies: 1Last Post: 16th Jun 2007, 09:50
