It's been a while since I posted here, so hello!
I just started using multiAVCHD and noticed a number(watermark) at the bottom of the movie for several seconds when it starts to play. Do I need to "donate" to get rid of this watermark?
Are there any menu templates (.MMT) available (other than the supplied ones) or must I create my own?
Any links that you have on creating menus would be much appreciated.
Thanks for your help....
No watermark as far as I know. What do these numbers look like?
There are some default entries in the Menus Titles headers & footers.
But you can put your own in or blank them out.
.mmt ?
Search http://multiforum.deanbg.com/index.php
Great program but not easy to follow at first as documentation is a bit sparse. -
Thanks for your quick response.
The value that I am seeing is "(01)00 00 00 000" in white text. This appears at the bottom of the screen when the movie first starts for a couple of seconds. I am not sure what is producing this. It is NOT in the .MKV file when I play it.
You will find the menu template files .MMT here:
C:\multiAVCHD\templates\menu
They can be Loaded/Saved in multiAVCHD.
Documentation "sparse" is putting it mildly
. I am pulling my hair out trying to figure out how to do a POSTER menu from this example:
SLIDE (with [x] Create single-title menu page option):
http://forum.doom9.org/showthread.php?t=143744
The example I am trying to duplicate is a menu for Wall-E with the POSTER.
I can NOT get a POSTER into the menu.
Open ffdshow config screen without opening a movie
By F u r u y á in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2013, 05:15 -
Sony Vegas Pro 11 & 12 Issue with crashing on opening splash screen.
By liberty610 in forum Software PlayingReplies: 8Last Post: 1st Nov 2012, 13:03 -
MultiAVCHD - what am i doing wrong?
By rz514 in forum Authoring (DVD)Replies: 15Last Post: 13th Feb 2012, 12:23 -
Some help needed with multiAVCHD
By VOYAGER2009 in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2011, 12:19 -
Problems opening mkv to make screen caps with frameshots
By Wizard23 in forum ComputerReplies: 3Last Post: 15th Feb 2010, 17:16
