Does it have to be PC capture cards?
Is there not something like a satellite TV box out there?
	My Hauppauge PVR-350 and Hauppauge USB-Live2 could both easily capture game footage. Of course I'd need to read the instructions first. I'd need to figure out (on my own) which recording codec would best suit my needs since I'd be editing the footage later....some recording codecs are MUCH easier to edit than others(like mpeg2)....and with free software as well(AviDemux)....and with ZERO quality loss after editing.
 For example I just captured a music video with my Hauppauge USB-Live2, then replaced the audio on the video with audio from the CD...ZERO quality loss to the video...all with a Hauppauge USB-Live2 and AviDemux.
	If you want to record in high definition, a computer almost has to be part of the picture. I have seen a couple of HD capture devices that record to an HDD or SSD without being connected to a computer, but a computer is necessary to work with the recordings.
 There probably isn't any satellite TV box available in the UK that can record in high definition from a component input or HDMI input. The HD satellite and TV set top recorders I have looked at online can record the output from their tuner, or the input from standard definition video and audio connections. Unless they are equipped with an optical drive, there is no way to export recordings from the hard drive, and most even encrypt the recordings on their hard drive to make things even more difficult.
	I've been told this is actually a discontinued model, but this has piqued my curiosity a few times over the past month or so....before I found a way to get my USB-Live2 to record PAL60.
 http://www.emtec-international.com/en-eu/S800H_Movie_Cube
  Record PC Screen with the Hauppauge HDPVR Gaming Edition?By rogvid700 in forum Capturing and VCRReplies: 5Last Post: 31st Jan 2012, 17:47
  Gaming cpu to record HDMI inputBy impelledram in forum DVB / IPTVReplies: 10Last Post: 17th Aug 2010, 18:33
  Record PC gaming, Alternative to FRAPsBy Perl43 in forum Capturing and VCRReplies: 0Last Post: 19th Jul 2010, 00:40
  Sporadic signal losses while capturing analog gaming footage w/ camcorderBy Nintendo Fan in forum Capturing and VCRReplies: 0Last Post: 17th Oct 2008, 19:45
  DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 14:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
