I recently created my second Pro Show Gold video.
It was a memorial video with 94 slides and came out great. It rendered and I copied it to four discs.
Then I moved the photos and file to an external hard drive with more memory.
When I went to open the file/movie again, all the pictures were gone.
I got back one of the original discs and it automatically plays the video. I would like to copy the video to hard drive and then burn several more copies.
I'm not seeing a single file that looks like "the" video but several files in a folder called VIDEO_TS with file names:
VIDEO_TS.BUP
VIDEO_TX.IFO
, etc.
How do I get the video from the disc onto my hard drive and then back onto other discs?
It's a normal dvd, see https://www.videohelp.com/dvd#struct
It's easiest to copy the entire disc. Use for example imgburn, make an iso from the dvd, then burn the iso and you will get a new dvd-video.
And you should ALWAYS keep the original photos because video slideshows are often in much lower quality. -
Thanks, Baldrick. Appreciate the info. I think I've got an idea of what to do now.
Unfortunately, the photos dropped out of the file transfer...which Pro Show Gold says can happen when moving or copying them. Weird.
Quicktime Pro - Getting Codecs to Show in List
By theWallflower in forum Video ConversionReplies: 4Last Post: 8th Apr 2010, 08:00 -
Giveaway of the Day - Gold Wave Editor Pro
By VirtualDoobMon in forum AudioReplies: 1Last Post: 23rd May 2009, 08:25 -
What HW/SW do I need to broadcast a semi pro TV show?
By sheikvid in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2008, 11:09 -
Premiere Pro CS3 and TMPGEnc - Can import AVI but video does not show up...
By chadsxe in forum Newbie / General discussionsReplies: 4Last Post: 15th Feb 2008, 14:05 -
Mini dv to dvd but show no date and time
By tn2006 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Jan 2008, 19:05
