Hi all,
I've been experimenting with video & audio conversions for some time & this is the first time I've come across this problem.
I've remuxed my Star Wars BD's to MKV to be played via my WDTV Live SMP. As the WDTV doesn't support DTSMA I usually convert the audio to flac (using the Arcsoft decoder & eac3to).
Problem is, any audio other than the original DTSHD track renders the MKV unplayable on the WDTV (I get a file type not supported error message). If i keep the DTSHD track it's recognised & plays fine.
I've tried numerous variants of format & container (M2TS with LPCM etc) & several different converters, all with the same result; 'File not recognised'. Strange thing is, they play fine on the PC & it's never happened with any of my other ripped BD's, only these Star Wars ones.
The natural conclusion to come to is that it's a problem with the WDTV, but I'm curious to know if anyone else has had the same problem & if you managed to find a solution.
Cheers,
Fred.
Your post is contradictory. First you say
OK. Many of us have the WDTV and we understand this. But then you say
If it "plays fine" then you don't have a problem. Does it or does not "play fine" if using DTS-MA in the MKV on the WDTV? Playing fine on the PC only proves that the audio is OK, not that the WDTV can play it.
Probably not the answer you're looking for, but if you use eac3to to convert your audio to AC3, it will probably work. -
Does the WDTV support header compression removal? I'm just wondering if the the MKVs have been remuxed using it after the audio has been converted?
Sorry if I wasn't clear;
I extract the uncompressed tracks from the BD, convert the audio & then remux to MKV.
Any combination of audio & container plays fine on the PC. The WDTV will only recognise the file (regardles of container) if the audio is the original unconverted DTSHD track.
I convert the DTSHD to PCM or flac so that I can pass through some form of HD audio signal to the receiver. If I was to convert the DTSHD to AC3 I'm no better off than I would be with the DTS core that is currently passed through by the WDTV. -
WDTV Live Plus plays those files, latest fw, but OP has WDTV Live SMP who knows.
Is length for that audio the same as video? ClownBD demuxes to streams with the option to re-encode main audio to AC3 (if it is DTS MA then just check one box) then video+those two audio streams mux with mkvmerge. Never had a problem. Never tried Star Wars unfortunately and I never will I guess .ClownBD uses eac3to as well but with those BD's it is all about to pull right length or get right playlist together I think. -
Update:
I've discovered that the issue I'm experiencing has something to do with the Arcsoft DTS decoder's (in conjunction with eac3to) inability to remap DTSHD 6.1 tracks when converting to another format (or something along those lines). DTSHD 5.1 & 7.1 pose no problem at all.
If I downmix the 6.1 track to to 5.1 when converting, the file plays fine.
Apparently, I'm not the first person to come across this rather specific conversion anomaly after all.
Is there another relatively easy way to losslessly convert DTSHD to WAV without using the Arcsoft & eac3to combination (my Googling has yielded no real clear answer)?
AVStoDVD audio out of sync on converted mkv
By whammoed in forum DVD RippingReplies: 23Last Post: 11th Jul 2014, 11:00 -
unplayable MKV
By chipstter in forum Video ConversionReplies: 5Last Post: 15th May 2012, 08:03 -
SUPER settings for .h264/ac3 to FLV renders unplayable file
By TigerLord in forum Video Streaming DownloadingReplies: 1Last Post: 15th Jan 2011, 19:15 -
Converted mkv has extremely slow audio
By PandaShake in forum Video ConversionReplies: 5Last Post: 4th Jul 2009, 04:15 -
Backing up ORIGINAL dvds renders them unplayable? HELP!
By emanpunk in forum DVD RippingReplies: 31Last Post: 2nd Mar 2009, 19:37
