anyone recommend a good sharpener for this source? I was think lsfmod since it doesnt create to much noise and can sharpen the lines.
Results 1 to 9 of 9
forum.videohelp.com/attachment.php?attachmentid=15114&stc=1&d=13552020 00
Having troubel uploading a sample video? You can always post a request for help in this thread.
Generally, to upload a sample video click on "Upload files/Manage attachments" in the lower-left corner of the thread's Reply window. The uplaod dialog window has info about acceptable formats and file sizes.
What are you trying to upload?Last edited by sanlyn; 24th Mar 2014 at 12:13.
That's not a source; that's an XviD AVI. A source would be the DVD or TV capture from which that XviD AVI was made.
And it already looks pretty sharp to me. There are some "soft" titles in sections, but they're pastel soft-focus stuff that seems to be designed to look that way on purpose.
You mentioned LSFMod, it's a popular sharpener. Its documentation has decent notes on the various settings. For instance there's a setting for edge sharpening only, no edge sharpening, or sharpen everything. There's another setting that helps prevent the "shiny" or plastic look on bright highlights if necessary. Most people just use the defaults and don't realize that it's a very versatile tool.
AVIsynth sharpener suggestions
By spicediver10191 in forum EditingReplies: 0Last Post: 29th Apr 2012, 07:33 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
why is there 16:10? Is 16:9 not good enough??
By turk690 in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2008, 19:07
