Hello there. I am trying to normalize a playlist. Is it possible with MPC-HC? do I need a plugin?
Currently, some playlist items are louder than other ones. Any ideas that dont involve taking each file into premiere and manually normalizing them.
thanks!
MPC-HC has a normalize function. It's in the audio switcher section. Try also checking "regain volume".
The above just gets MPC-HC to slowly increase the audio level during the quiet bits, then it quickly drops it during a loud bit, then it slowly turns the volume up again until the next loud bit etc...... it's not ideal but it's better than nothing.
What type of files does the playlist contain and what type of audio?
Reading AVCHD Playlist files BDMV\Playlist\*.mpl
By StrangeSolutions in forum Newbie / General discussionsReplies: 11Last Post: 10th Jun 2014, 23:23 -
64-bit real media plugin/codec for MPC-HC?
By cheerful in forum Software PlayingReplies: 0Last Post: 3rd Oct 2010, 07:01 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41 -
mkv video audio normalization / post-processing audio normalization
By o6uoq in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2009, 00:17
