Results 31 to 42 of 42
ok, -vcodec h264 calls libx264 as well, and -x264opts open-gop encodes, but command isn't passed through (still closed)
so use this
-x264-params open-gop=1 -
Hello,
I tested HEVC and H.264 but I do not obtain satisfying results.
I would want to know if I did not configured HEVC properly, or it is normal to be like this.
So, lossless mode, for a Gop of size 4, input video format CIF
= > compression ratio h.264 = 42%
compression ratio HEVC = 50%
Or for lossy mode, 1bit/pixel, Gop of size 4
=> PSNR luma h.264 = 30dB
PSNR luma HEVC = 31db
In lossy mode I do not obtain a better quality compared to h.264
If you have some ideas, please help me. -
Hi,
I encoded a few frames of BigBuckBunny.yuv using HEVC and specifying a target bitrate of about 0.5bit/pixel. I noticed that the size of binary file decrease as the GOP size is larger. So, what is the role of target bitrate? Does it depends on Gop size? I was expecting to find the same final bitrate no matter the Gop configuration
thank you in advance -
Hello Everybody...
Is there anyone know the algorithm of HEVC encoder and decoder?? such as the flowchart ??
Best Regards -
iirc https://app.box.com/s/rxxxzr1a1lnh7709yvih contained some charts,..
http://iphome.hhi.de/schierl/assets/hevc_icassp2012.pdf also contains a general diagram of a HEVC decoder
Thanks a lot for your support. I actually need it because I want to understand the HEVC encode/decoder how it works. Since I need to design a teleconference using HEVC codec, that's why I need to understand each step.
Thanks again and best regards.
Zond 265, the first professional HEVC / H.265 Analyzer from SolveigMM
By DmitryV in forum Latest Video NewsReplies: 5Last Post: 13th May 2024, 10:02 -
Encode h.265
By sportsstar89 in forum Video ConversionReplies: 13Last Post: 5th Jan 2015, 04:00 -
H.265 codec: Double Video Quality on Existing Data Rate
By roma_turok in forum Latest Video NewsReplies: 0Last Post: 18th Aug 2012, 11:35 -
Mastertech DVD-265
By jhv in forum Newbie / General discussionsReplies: 1Last Post: 19th Aug 2011, 14:59 -
best free DV to DVD encoder???
By tmh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 7th Mar 2008, 13:39
