I want to know what's the best way to convert/compress a DVD (VOBs) into H264 (AVI) with subtitles. I'm currently using Avidemux 2.5/2.6 and it seems to be doing a pretty good job. I use SubRip to rip the subtitles.
I was wondering if there is any programs better than Avidemux? Or any recommendations on DVD ripping tutorial?
Results 1 to 9 of 9
Handbrake. It can do everything for you.
Rip with anydvdhd or dvdfab decrypter. -
Select to open a dvd and choose the video_ts folder with all vob,ifo,bup files.
I generally use DVDShrink to rip/re-author the DVD, with AnyDVD running in the background to do the decrypting, although I believe the free version of DVDFab can be used to decrypt the disc in the same way. Once the DVD is ripped to your hard dive properly if you want to convert to AVI then I'd still recommend AutoGK. You shouldn't need to extract the subtitles manually. AutoGK will load them from the vob files.
For converting using the x264 encoder there's lots of choices but I'm also partial to MeGUI. -
H264 Rip.. Size? or
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 7th Feb 2011, 02:05 -
MKV-h264 bd rip to external hard disk
By Flashgun in forum Video ConversionReplies: 2Last Post: 1st Sep 2010, 11:24 -
How to convert DVD TV episodes to AVI Xvid or MP4 H264 with subtitles
By Baldrick in forum User guidesReplies: 9Last Post: 5th Jun 2010, 03:06 -
Any way to rip/demux .ts h264 subtitles?
By rocka in forum DVB / IPTVReplies: 5Last Post: 2nd Jun 2010, 16:08
