  1. All of a sudden, on a Compaq notebook running XP, when I invoke Task Manager, all the options are missing, as shown in the attached screen capture.
    I thought perhaps TM has gotten corrupted, but I copied TM from another computer which shows all the options (tabs, etc.), but the same thing happened.
    Any ideas?
    EDIT: Never mind! Found the solution by using better search terms . . . . When no options show, TM is running in something called "tiny mode," invoked if you double click in the blank part of the border. Double-clicking again restores full features. This was clearly a self-induced ID10T error.
    Last edited by CobraPilot; 8th Dec 2012 at 23:33. Reason: Found solution on my own.
  2. Member vhelp's Avatar
    Mar 2001
    New York
    hi, go to menu, View\Select Columns..
    choose whatever fields you want to see.
    edit: nevermind, you found your solution
  3. DECEASED
    Jun 2009
    Heaven
    @ vhelp:
  4. Thanks for the suggestion, vhelp, but when in this new-to-me "tiny mode," there is no way to get to any of the menu options. You have to be OUT of "tiny mode." ["Tiny mode"? Who came up with THAT one?]
    This learning experience came on a notebook that has a very hard-to-click left touchpad button. I obviously accidentally double-clicked in the area which activates TM, probably trying to get just a single click.
    Live and learn . . . .
