Can someone help?
I left AVStoDVD running overnight on a .mp4 file. The original file was too big to burn to DVD (over 4.7GB) so as I understand it the AVStoDVD program was going to shrink the original file and also make it into something it could then burn onto a single-layer DVD.
Well, the next morning this message greeted me: "Process aborted during DVD AUTHORING operations!". There are some text documents, which I assume are log files, along with a video file (4.1GB) and a couple of small audio files (2 expected commentary tracks).
I sense that the operation was aborted in a non-critical phase, as tested independently the video and audio tracks play with VLC media player but there is no unified file/folder. Is the 'authoring' stage where the video and audio tracks are made into something that can be written to a DVD disc? Can I somehow finish this operation with the data that has already been created and without having to start from the beginning again?
Attached log files.
Hi Jockie,
unfortunately the log files are not helpful in this situation.
I would suggest you to:
1. Open Muxman (it comes with AVStoDVD, you can find it in AVStoDVD installation folder)
2. Add the video file (m2v file, the big one)
3. Add the audio files (ac3)
4. Select destination folder
5. Start
Report here any errors Muxman gives to you.
Bye
AVStoDVD MP4 problem Process Aborted during subs encoding operations
By stem300 in forum Authoring (DVD)Replies: 7Last Post: 22nd Nov 2012, 12:38 -
AVStoDVD mkv problem Process Aborted during subs encoding operations
By stem300 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2012, 17:08 -
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 18:57 -
What is the problem when it says "failed video encode, aborted "?
By PERSHON in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 12:33 -
AVStoDVD 2.3.2 - Process aborted during DVD Burning Operations
By Mark97213 in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2010, 14:05
