Are there any that would work with it? I've tried programs like Virtualdub etc. but they never work, as I thought they would. The software bundled with the RGCHDP is pretty bad, and all it does is take up all of your CPU power for absolutely no reason(causes distorted previews etc.). Are there any programs that would work with it? Programs that usually work with devices that have hardware encoders?
The device driver modules that control hardware encoding don't seem to be very standardized across capture devices. That means capture software has to be designed to use the encoding module for that particular device, which understandably limits your choices quite a bit.
You might be able to build a filter graph using GraphStudio or GraphEdit, and use it to capture, but that isn't always easy. Sometimes it takes a lot of trial and error to create a working graph.Last edited by usually_quiet; 8th Dec 2012 at 10:42. Reason: removed a word for clarity
From the above, I take it that you have used GraphEdit to successfully build working filter graphs in the past, but are stumped by the Roxio Game Capture HD Pro. That is unfortunate as I am not able to offer you any advice on building filter graphs beyond the basics. I can't experiment with building graphs for the Roxio Game Capture HD Pro because I don't own one.
Have you also tried installing the service pack update for the Roxio software to see if that helps? -
There are only two sorts of capture devices using hardware encoding that I know of which are supported by third party aps other than GraphEdit or GraphStudio, although the third party software choices are limited to a few PVR aps.
One category is TV tuner cards with an analog tuner and analog capture port. The other category is made up of a few older HD capture devices, the AverMedia HD DVR USB, the Hauppauge Colossus and the original Hauppauge HD PVR, which can masquerade as digital tuners with the right drivers or software plug-in installed.
I think your only 3rd party option for the Roxio device that you have at this point is to keep trying with GraphEdit or GraphStudio. -
Tip:
Install a virtual machine with XP and only install ROXIO HD drivers + DirectX.
After this, use graphstudio/edito to make your tests. Too easy.
Any find, post here.
Claudio
Is there a proved working USB capture device with 3rd party software?
By ndep in forum Capturing and VCRReplies: 6Last Post: 18th Mar 2013, 01:55 -
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 16:30 -
Is there 3rd party software to let WinTV USB 2.0 PVR capture widescreen?
By GSP_87 in forum Capturing and VCRReplies: 6Last Post: 28th Jun 2012, 07:44 -
Question regarding the Roxio Game Capture
By danschmiedeler in forum Capturing and VCRReplies: 3Last Post: 6th Dec 2011, 23:49 -
Roxio Game Capture
By Agent 0008 in forum Capturing and VCRReplies: 2Last Post: 3rd Apr 2011, 13:22
