Results 1 to 19 of 19
    Dec 2012
    Boca raton, florida , usa
    Strange.... there must be a ghost in my computer. This also is not working on my other laptop. i am testing with 2 laptops.
    Objective : to burn a dvd movie to play in a dvd player
    Tools: I have .avi movies, wmv movies formats and more. I have magic iso, windows movie maker and santa dvd maker. The dvds i am using are called SONY DVD-R 120min 4.7GB
    Problem: I am using programs, They all go through and say that the dvd has been made successfully, but when I put the dvd into a player and play them, "incorrect disc", also when I put the dvd in my laptop to play it it says "its a blank disc"
    What is going on? I can't burn a dvd movie? Do I need iso? what is this ghost ?
    I have used many tools, Its just odd. Maybe you know something I don't know
    does it need to be in iso ?? not sure. but i doubt it.
    Thanks in advance pros.
    Are you burning with santa dvd maker?
    I would use something better. Like ConvertXtodvd 5 or AVStodvd and burn it with imgburn.
    Dec 2012
    yes. i have burned with a lot of things. Santa said completed, but dvd still not playing. TV says incorrect disc, and Laptop says blank disc. (when santa confirms completed)
    Dec 2012
    so i have to convert it to DVD? please explain if you have time. Thanks in advance.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    I guess santa dvd maker does that for you. But I have never used it.
    Can you burn dvds with other software okey?
    Dec 2012
    no. i tried other software, nothing...........
  7. Member DB83's Avatar
    Jul 2007
    Are you sure you are actually 'burning' ?
    You put the blank disk in to your PC drive and can you see evidence of the disk being burned. That is the drive light comes on and stays on (or blinks) throughout the burning process. That itself could take some 10 minutes.
    Dec 2012
    the light is blinking right now as i am burning with image burn. its crazy lol. what i did was took an .avi movie file, and used image burn to make an iso with it then burn it. Does it need to be an iso ? well i am doing it now . lets see if this works.
  9. Member DB83's Avatar
    Jul 2007
    Imgburn does not need an iso. In fact I did not think it actually makes an iso from anything.
    You seem horribly confused.
    Your authoring programs should create a folder called Video_TS. You import that folder in to imgburn NOT THE FILES INSIDE THE FOLDER and burn that.
    OR you create an iso from the folder and burn that. But be careful as to which option you use as imgburn treats these differently. Otherwise you simply end up with a file called XXX.iso on that disk and that will not play either.
    Dec 2012
    well, so i have to author each dvd?? what program to i use to make a _TS.? and where do i save it
    Dec 2012
    i am such a dumbass. the movie i was trying to burn was currupted. now i am burning a nice one. lets see if this works.
  12. Member DB83's Avatar
    Jul 2007
    Well both of the programs you have used will author the dvd.
    But having not used either, I do not know whether it is a two stage process or one. For two stages, the first stage is 'authoring'. That creates all the files required by the second stage - the burning process. The program should then have the neccessary options to be able to load the files wherever you saved them before you actually BURN the disk.
    A one-stage process would do all this automatically as long as there is a disk in your dvd-burner.
    A 'corrupt' movie should not result in an empty/incorrect disk. The program should give ample warnings if the source movie was bad.
    It has already been suggested to you what to use. AVS2dvd for the authoring and imgburn for the burning. Both of these are proven.
    Dec 2012
    ok. so far. still no success. i used winavi and other converters. they nicely convert to _TS files. Then i opened imgburn and did write files to disc. image burn said operation completed. put it in my dvd player and nothing.
  14. Member DB83's Avatar
    Jul 2007
    Will you just do what has been suggested and NOT what you think is best.
    _TS is NOT a file. It is the folder that is created by the authoring process.
    Dec 2012
    ok i am doing exactly what you suggested now. installing avs to dvd. and using imgburn. lets see what happens
    Dec 2012
    quick questtion. when it asks me to do it in PSL or that other format, which one do i do it in.
  17. Originally Posted by jamescali View Post
    If you are from US, you should choose NTSC and not PAL.
    Bye
    MrC
    AVStoDVD Homepage
  18. Member
    Dec 2012
    damn i choose pal.
    Dec 2012
    muxman is finalizing dvd lol........
