Hello!
how can convert dts AUDIO file with 5.1Ch in MKA format to a audio file format with same channel(5.1) count?
i need a format for importing to adobe premier.
explain:
i have a mkv film. and mp4 film.
both are in 5.1CH with up 320Kb Bitrates.
i want edit these file with another audio file in premier.
"MKA" is an audio file format. However, in trying to read between the lines, what I believe you are asking is: "how can I convert this audio file to a similar format that IS compatible with Premiere?"
The answer to that is use eac3to to convert the dts to ac3 (and in doing so, demux the mka to raw). If for some reason eac3to cannot read the mkv/mka file, demux it to raw FIRST, with AVIMux-GUI or another MKV-aware muxing/demuxing app. Then you would have a .DTS file.
No matter what you do, you'll need to re-encode. Whether to use 5.1 AC3 (as suggested) or as a 5.1 WAV/BWF file (should also work in eac3to and in Premiere), is your choice. But those are really the only 2 multi-channel choices that would work smoothly in Premiere.
Scott -
Assuming premier will play with dts files it's easy enough to extract the dts audio from the mka file using MKVCleaver. MKVCleaver requires MKVToolNix installed in order to work. Once it's extracted the audio stream you'll have an audio file with a .dts extension.
Premiere MAY have an encoder for outputting DTS files, but it DOES NOT import DTS, so that is a non-starter.
Scott -
MKA is a container associated with Matroska:
The MKA file type is primarily associated with 'Matroska' by Matroska Association. The Matroska multimedia container formats were derived from a project called MCF, but differ from it significantly because it is based on EBML (Extensible Binary Meta Language), a binary derivative of XML. EBML enables future format extensibility, without breaking file support in old parsers. This is a container, not a CODEC. Get the parser from the Matroska site. MKA files are typical matroska files containing only audio information, but no video. These files may typically comprise a complete music album in one single file, where file chapters mark each song. In addition to that the file can have attachment like lyrics or cover JPEGs, or even show a Karaoke subtitle stream.
If there is DTS 5.1 files inside, they'd have to be extracted as hello_hello stated. As long as they're in a .wav format they should be easy enough to work with.
Sony Vegas would be an option considering there is video and audio involved.
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 22:59 -
Need help as mkvtoolnix extracts dts audio as mka and ineed it as ac3 help!
By csta in forum MediaReplies: 1Last Post: 12th Aug 2011, 03:17 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
Possible to convert a 5.1CH 4608kbps PCM audio track to a 1536kbps 5.1 DTS?
By fluxcapacitormb in forum AudioReplies: 4Last Post: 20th May 2010, 15:46 -
Converted mkv file can't keep DTS audio
By thegrube in forum Video ConversionReplies: 4Last Post: 11th May 2009, 15:49
