I made a photo CD in VCD format using a bunch of JPGs and Nero and I would like to know if there is anyway I can rip the pictures back onto my hard drive.
You've confused me. Did you embed the photos into a video stream? If so, then load your VCD into a software DVD player that will allow you to do a SCREEN CAPTURE (I use Power DVD 4.0) and capture your photos one by one.
Otherwise, look at the VCD disk and see if you can find the .JPGs on the disk. If so, then simply copy them back to your HD (no need to "rip"). -
No, its not a slide show. I just dragged the jpg over in Nero as if they where MPEGs. They Don't rotate or anything. it kind of like just one really long menu.
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Aug 2010, 00:01 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22 -
Which program for Photo VCD?
By OS_Man in forum VCDEasy GeneralReplies: 1Last Post: 11th Jul 2007, 13:53
