    Jul 2008
    I have and been keep trying over and over again to split a DVD in 2 using IFOedit without any sort of quality lost. The main problem that is holding me up is what files are missing after the split is done, so I could manually copy those files over? What if I run into this problem again, what is the easiest way to know what files I should copy over?
    Here is the guide I am following: http://www.doom9.org/index.html?/mpg/ifoedit-2dvdrs.htm
    Thank you,
    Jul 2008
    Thank you, Baldrick!
    Your method was a lot easier, and it is about to solve everything for me. I should of used that method instead of using something more advanced.
    Thank you again!
