Closed Thread
    Dec 2012
    india
    hi,
    i had a movie file downloaded which is showing the up-loader's name (about 5 secs)..
    how can i remove it ,i don't want to remove or fill color to the frame( which will affect movie & subtitle timing)
    is it possible to do it..
    Apr 2003
    Let me warn you that you will not get any help here on how to edit your obviously ill gotten gains. The image you uploaded clearly shows that the movie is pirated.
    Consider yourself warned! I am being nice; others may not be so nice.
    Brainiac
  3. Sure, I'll help him. Cut out between the keyframes the part with the logo. Reencoode it using a logoremover to get rid of it. Then stick the reencoded part back into the movie. It'll leave a big blur where the name was before. Or cover it with a black or blur rectangle.
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Brainiac, the OP is asking for advice to remove a logo, not how to bootleg anything.
  5. Banned
    Nov 2005
    or even simpler just cut out the 5 seconds at the very beginning which obviously has nothing to do with the movie.
  6. Originally Posted by deadrats View Post
    Yes, but he specifically mentioned not wanting to just cut it out as that would mess up the subs. Left unsaid is the fact that it's easy to retime the subs, and if he doesn't need the beginning your suggestion is the way to go.
    Because he already knows how to bootleg movies.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Buy the DVD:
    http://www.amazon.com/Matrix-Revolutions-Two-Disc-Widescreen-Edition/dp/B0001BKAEY
  8. I'm a Super Moderator johns0's Avatar
    canada
    Pleas but the movie,thread closed.
