I'm not sure if this is haloing or not, but I see it in a few scenes and I'm not very experienced with dealing with it. You can clearly see it along the white part of her shirt (on the right side).
http://oi45.tinypic.com/r1zbia.jpg
If someone could tell me exactly what this issue is and how it could be fixed, I'd be very greatful.
The image was oversharpened on the vertical axis causing halos on horizontal edges. The cure is to blur along the vertical axis. Of course, then the lines won't be real sharp. So you can use an edge enhancer that doesn't create halos and a line darkener.
Alright, I'll try that along with FastLineDarken and LimitedSharpenFaster and see if it is any better.
What you really want for sharpening are filters that can work only the vertical dimension. Otherwise you will oversharpen horizontally. In lieu of that you can try something like doubling the width, running those filters, the restoring the width.
Jagged Edge Of Video Picture
By kenryuakuma in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2011, 08:24 -
Why does the disney hd channel have their logo on the 4:3 edge vs 16:9?
By yoda313 in forum Off topicReplies: 11Last Post: 13th Apr 2011, 16:22 -
black edge on netmeeting
By ahidayat in forum Newbie / General discussionsReplies: 0Last Post: 21st Mar 2009, 04:35 -
Hexen: Edge of Chaos - Doom3 Engine...
By retroborg in forum Off topicReplies: 1Last Post: 25th Oct 2008, 09:24 -
Blur edge of video in vegas?
By macca1980 in forum Newbie / General discussionsReplies: 5Last Post: 29th Apr 2008, 03:37
